Archives de la liste
Re: [Starpu-devel] Online Performance Monitoring With Performance Models in Fortran StarPU
Chronologique Discussions
- To: Marcelo Cogo Miletto <marcelo.miletto@inf.ufrgs.br>
- Cc: starpu-devel@lists.gforge.inria.fr
- Subject: Re: [Starpu-devel] Online Performance Monitoring With Performance Models in Fortran StarPU
- Date: Tue, 20 Oct 2020 15:13:00 +0200
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
Hi,
Thanks for the report. The Fortran API is basically extended on demand, and
that feature had not been requested so far.
I have now added some minimal support for using performance models from the
Fortran API in the "master" branch of the StarPU repository.
The example file "examples/native_fortran/nf_vector.f90" shows an example on
how to use this.
Best regards,
Olivier Aumage
> Le 20 oct. 2020 à 13:00, Marcelo Cogo Miletto
> <marcelo.miletto@inf.ufrgs.br> a écrit :
> Dear StarPU team,
> I have been trying, without success, to use a performance model for
> online performance monitoring in a Fortran application that uses
> StarPU (release 1.3.7) to use data-aware schedulers. The best result I
> got so far was an empty model being dumped in the
> $STAPU_HOME/.starpu/sampling/codelets/45.
> I tried to include functions in the src/util/fstarpu.c and in
> include/fstarpu_mod.F90, to allocate and configure the performance
> model, assigning it to a codelet in a very similar way to how the task
> codelet structure creation and configuration is done in the Fortran
> examples (e.g., using fstarpu_codelet_allocate, fstarpu_codelet_set_name).
> I use a c_ptr type variable in Fortran that should hold the performance
> model structure address. Then, I set its symbol and its type to
> STARPU_HISTORY_BASED, initialize it by calling starpu_perfmodel_init, and
> assign it to the codelet structure using cl->model = &my_model, all
> this with the functions abovementioned.
> Other things that I have considered:
> - STARPU_CALIBRATE set to 1
> - STARPU_SCHED set to dmda
> - Application calls fstarpu_init
> - Application calls fstarpu_shutdown
> The performance model dumped file reports that model->state->ncombs is
> 0, so it does not print anything after the file header:
> # Performance Model Version
> 45
> # COMBs
> # number of combinations
> 0
> At this point, I'm a little bit lost on where the problem is. As I'm
> not very acquainted with Fortran, I wonder if this is the right path
> to use such models in a StarPU Fortran application. Also, I would find
> helpful if you have some minimal code example on how to do it properly
> to share with me.
> Best,
> Marcelo Miletto.
> _______________________________________________
> Starpu-devel mailing list
> Starpu-devel@lists.gforge.inria.fr
> https://lists.gforge.inria.fr/mailman/listinfo/starpu-devel
- [Starpu-devel] Online Performance Monitoring With Performance Models in Fortran StarPU, Marcelo Cogo Miletto, 20/10/2020
- Re: [Starpu-devel] Online Performance Monitoring With Performance Models in Fortran StarPU, Olivier Aumage, 20/10/2020
- Re: [Starpu-devel] Online Performance Monitoring With Performance Models in Fortran StarPU, Marcelo Cogo Miletto, 20/10/2020
