Archives de la liste
- To: Cedric Augonnet <caugonnet@nvidia.com>
- Cc: "starpu-devel@inria.fr" <starpu-devel@inria.fr>, "thomas.morin@etu.u-bordeaux.fr" <thomas.morin@etu.u-bordeaux.fr>
- Subject: Re: [starpu-devel] Using OpenACC to write GPU-accelerated kernels
- Date: Thu, 10 Mar 2022 12:55:12 +0100
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=samuel.thibault@labri.fr; spf=Pass smtp.mailfrom=samuel.thibault@labri.fr; spf=None smtp.helo=postmaster@v-zimmta03.u-bordeaux.fr
- Ironport-sdr: EejxD+fhO+KWOLsw6gxf/IC63kjERU8KZNih9StZEqoQpZgtbPLv9Ca14ir3edZKNf6naYKT+t q3KILmXWGOt27PnpHwUYSqoqPWUcVo+gkRNgNNsfevHqizC++zTUY/BukduysjKQOsKRHJMoye CRZm0GSpJOthbwL9ge4RYZ+9x8BUPTrUQhthIjT7DV/ijgNoAwYOb0otA1zk5UYD++BE2jbX94 0XfZkUW/70qTKFROq2mxFLqctxMQ7UJYfLi+PUYv+LYE2vcmc4dVm5d1aYgTB3SqWquYyR1A8/ e6A9ZSsHYvtWhouSKeNtf6WI
- Organization: I am not organized
Hello,
Thanks a lot!
That'll save us reading docs to find these few couple bits of plugging :)
Samuel
Cedric Augonnet, le jeu. 10 mars 2022 09:55:57 +0000, a ecrit:
> From recent discussions with people using StarPU, I felt it could be
> somewhat
> useful to provide you with examples of kernels generated with OpenACC, which
> can probably make it much easier to write effecient GPU versions of your
> codelets. Note that if you are using CUDA, you probably already have access
> to
> these compilers anyway.
> If you are using NVIDIA compilers, that should be pretty easy with the -acc
> knob, and by following the example number 3. If the code is using another
> compiler, you can still generate a dynamic library and use it as shown in
> example 2.
> Best,
> Cédric
- [starpu-devel] Using OpenACC to write GPU-accelerated kernels, Cedric Augonnet, 10/03/2022
- Re: [starpu-devel] Using OpenACC to write GPU-accelerated kernels, Samuel Thibault, 10/03/2022
