Accéder au contenu.
Menu Sympa
starpu-devel - Re: [starpu-devel] Trouble with OpenCL+MacOS+STARPU+GCC+MPI
Archives de la liste
Chronologique Discussions
  • To: Susana Munguia <susana.munguia56@gmail.com>
  • Cc: starpu-devel@inria.fr
  • Subject: Re: [starpu-devel] Trouble with OpenCL+MacOS+STARPU+GCC+MPI
  • Date: Fri, 12 Aug 2022 20:21:12 +0200
  • Authentication-results: mail3-relais-sop.national.inria.fr; dkim=none (message not signed) header.i=none; spf=SoftFail smtp.mailfrom=samuel.thibault@inria.fr; dmarc=fail (p=none dis=none) d=inria.fr
  • Organization: I am not organized
Hello,
Susana Munguia, le lun. 01 août 2022 13:35:43 -0700, a ecrit:
> [starpu][_starpu_opencl_locate_file] Error: Cannot locate file <examples/
> basic_examples/block_opencl_kernel.cl>
> [starpu][abort][_starpu_opencl_locate_file()@drivers/opencl/
> driver_opencl_utils.c:94]
> zsh: segmentation fault STARPU_SCHED=dmdas ./block
Since it seems to be looking at
examples/basic_examples/block_opencl_kernel.cl, make sure to run it from
the starpu/ directory, so that that path is valid.
Samuel
Haut de le page
