Accéder au contenu.
Menu Sympa
starpu-devel - Re: [starpu-devel] Warning when running the code
Archives de la liste
Chronologique Discussions
  • To: Doru Adrian Thom Popovici <dtpopovici@lbl.gov>
  • Cc: starpu-devel@inria.fr
  • Subject: Re: [starpu-devel] Warning when running the code
  • Date: Mon, 17 Jul 2023 09:42:41 +0200
  • Authentication-results: mail2-relais-roc.national.inria.fr; dkim=none (message not signed) header.i=none; spf=SoftFail smtp.mailfrom=samuel.thibault@inria.fr; dmarc=fail (p=none dis=none) d=inria.fr
  • Organization: I am not organized
Hello,
Doru Adrian Thom Popovici, le sam. 15 juil. 2023 21:03:02 -0700, a ecrit:
> I am getting the following warning:
> [starpu][nid001200][_starpu_init_cuda_config] Warning: could not find
> location
> of CUDA0, do you have the hwloc CUDA plugin installed?
To optimize its driver thread placement, starpu uses hwloc to determine
where CUDA GPUs are in the machine. But that can only work if hwloc has
CUDA support enabled and installed. It seems your system doesn't have
that, so you should check that.
Samuel
Haut de le page
