Accéder au contenu.
Menu Sympa
starpu-devel - Re: [starpu-devel] Questions about StarPU communication backends
Archives de la liste
Chronologique Discussions
  • From: Philippe SWARTVAGHER <philippe.swartvagher@inria.fr>
  • To: "Yan, Jiakun" <jiakuny3@illinois.edu>, "starpu-devel@inria.fr" <starpu-devel@inria.fr>
  • Subject: Re: [starpu-devel] Questions about StarPU communication backends
  • Date: Mon, 2 Oct 2023 22:14:49 +0200
  • Authentication-results: mail2-relais-roc.national.inria.fr; dkim=none (message not signed) header.i=none; spf=SoftFail smtp.mailfrom=philippe.swartvagher@inria.fr; dmarc=fail (p=none dis=none) d=inria.fr
Hello,
Le 02/10/2023 à 19:52, Yan, Jiakun a écrit :
- Does StarPU have any backends other than MPI?
Yes, there is also the NewMadeleine's native interface, see the relevant section in the documentation: https://files.inria.fr/starpu/testing/master/doc/html/MPISupport.html#Nmad
- Are there any publications describing the network layer of StarPU (e.g. how StarPU uses MPI)?
Did you have a look on publications related to MPI support in StarPU: https://starpu.gitlabpages.inria.fr/publications.html#PublicationsOnMPISupport ? The paper we usually cite to refer the distributed support of StarPU is the following: https://inria.hal.science/hal-01618526
Depending on what you want to know, you might be interested by my thesis: https://theses.hal.science/tel-03989856, especially section 1.3.3 ("Distributed StarPU") and appendix A ("Differences between MPI and NewMadeleine backends in StarPU").
Assistant Professor @ ENSEIRB-MATMECA
Research team Topal @ Inria Bordeaux-Sud Ouest
Haut de le page
