Archives de la liste
- To: Doru Adrian Thom Popovici <dtpopovici@lbl.gov>
- Cc: starpu-devel@inria.fr
- Subject: Re: [starpu-devel] Creating tasks that are dependent on resources
- Date: Wed, 29 Nov 2023 10:52:59 +0100
- Authentication-results: mail3-relais-sop.national.inria.fr; dkim=none (message not signed) header.i=none; spf=SoftFail smtp.mailfrom=samuel.thibault@inria.fr; dmarc=fail (p=none dis=none) d=inria.fr
- Organization: I am not organized
Hello,
Doru Adrian Thom Popovici, le mar. 28 nov. 2023 10:07:46 -0800, a ecrit:
> I am trying to understand if it is possible to launch tasks that require
> different amounts of threads.
> For example, I have three tasks:
> A requires 4 threads
> B requires 2 thread
> C requires 6 threads
> I have a budget of 8 threads, so A and B can go first, however C needs to
> wait
> because it needs 6 threads but only two are available.
> I could also run C and B first, and then A has two waits.
> I have been reading the StarPU manual, however I am not clear if this
> feature
> is available.
With combined workers it is possible with the pheft scheduler. To
specify the amount of threads that a task should use, you can use the
can_execute callback and its workerid parameter and the
starpu_combined_worker_get_description function to get the size and
return 1 only if it's the one you want.
Note however that pheft is a released-first scheduler, without
backfilling (mostly a proof of concept). Help welcome on implementing
better parallel-task schedulers :)
Samuel
- [starpu-devel] Creating tasks that are dependent on resources, Doru Adrian Thom Popovici, 28/11/2023
- Re: [starpu-devel] Creating tasks that are dependent on resources, Samuel Thibault, 29/11/2023
