Archives de la liste
Re: [starpu-devel] [stencil based code: omitting last row and last column]
Chronologique Discussions
- To: Maxim Abalenkov <maxim.abalenkov@gmail.com>
- Cc: starpu-devel@inria.fr
- Subject: Re: [starpu-devel] [stencil based code: omitting last row and last column]
- Date: Tue, 30 Jul 2024 14:29:18 +0200
- Authentication-results: mail3-relais-sop.national.inria.fr; dkim=none (message not signed) header.i=none; spf=SoftFail smtp.mailfrom=samuel.thibault@inria.fr; dmarc=fail (p=none dis=none) d=inria.fr
- Organization: I am not organized
Samuel Thibault, le mar. 30 juil. 2024 14:24:21 +0200, a ecrit:
> Maxim Abalenkov, le mar. 30 juil. 2024 13:24:24 +0400, a ecrit:
> > I need to omit updating the boundary elements (last row and last column
> > elements) of my array. Please see the figure attached. The top left grid
> > depicts the first update stage where the last row needs omitting from the
> > calculation. The bottom left grid shows the second update stage, where
> > the last column of elements needs omitting. The shaded regions are the
> > elements I need to skip.
> > My question is: does StarPU have helper routines to skip calculation in
> > those regions?
> The starpu_vector_interface does not contain such information. But you
> can introduce your own data interface with the added field, and
> copy/paste the starpu_vector_filter_block function to add the update of
> the field.
(you'll also need to copy/paste the implementation of the vector
interface src/datawizard/interfaces/vector_interface.c)
Samuel
- [starpu-devel] [stencil based code: omitting last row and last column], Maxim Abalenkov, 30/07/2024
- Re: [starpu-devel] [stencil based code: omitting last row and last column], Samuel Thibault, 30/07/2024
- Re: [starpu-devel] [stencil based code: omitting last row and last column], Maxim Abalenkov, 30/07/2024
