Archives de la liste
Re: [starpu-devel] [StarPU-MPI: no dedicated thread for communication; function to set MPI_THREAD_MULTIPLE]
Chronologique Discussions
- From: Philippe SWARTVAGHER <philippe.swartvagher@inria.fr>
- To: Maxim Abalenkov <maxim.abalenkov@gmail.com>
- Cc: starpu-devel@inria.fr
- Subject: Re: [starpu-devel] [StarPU-MPI: no dedicated thread for communication; function to set MPI_THREAD_MULTIPLE]
- Date: Thu, 12 Sep 2024 15:15:25 +0200
- Authentication-results: mail3-relais-sop.national.inria.fr; dkim=none (message not signed) header.i=none; spf=SoftFail smtp.mailfrom=philippe.swartvagher@inria.fr; dmarc=fail (p=none dis=none) d=inria.fr
Le 12/09/2024 à 14:00, Maxim Abalenkov a écrit :
But, IMO, StarPU+MPI on Mac will give you poor performance anyway, so it doesn't really matter if you have +/- 1 core used for computations (for prototyping, for instance)…
Do you know, what is the reason for that? Why does StarPU-MPI perform badly on a Mac?
Because a laptop is not done for HPC :) You will have a lot of system noise adding too much variability to your results.
I have my code in StarPU for shared-memory and StarPU-MPI. I would like to run a simple performance comparison test between these two versions. Can you please confirm my logic? To run StarPU-MPI on a single node using only this node’s cores, I set the number of StarPU CPUs equal to the number of MPI. For example to have four MPI processes each running on a dedicated CPU core I will run my code as
STARPU_NCUDA=0 STARPU_NOPENCL=0 STARPU_NCPU=4 mpiexec -np 4 ./code
Is that right? Thank you and have a great day ahead!
This command will spawn 4 MPI processes, each using 4 CPUs for computations.
If you want 4 MPI processes with 1 core per MPI process, use something like
STARPU_NCUDA=0 STARPU_NOPENCL=0 STARPU_NCPU=1 mpiexec -np 4 ./code
Assistant Professor @ ENSEIRB-MATMECA
Research team Topal @ Inria Bordeaux-Sud Ouest
- [starpu-devel] [StarPU-MPI: no dedicated thread for communication; function to set MPI_THREAD_MULTIPLE], Maxim Abalenkov, 11/09/2024
- Re: [starpu-devel] [StarPU-MPI: no dedicated thread for communication; function to set MPI_THREAD_MULTIPLE], Philippe SWARTVAGHER, 11/09/2024
- Re: [starpu-devel] [StarPU-MPI: no dedicated thread for communication; function to set MPI_THREAD_MULTIPLE], Maxim Abalenkov, 12/09/2024
- Re: [starpu-devel] [StarPU-MPI: no dedicated thread for communication; function to set MPI_THREAD_MULTIPLE], Philippe SWARTVAGHER, 12/09/2024
