Accéder au contenu.
Menu Sympa
starpu-devel - [starpu-devel] Darts + Out of Core
Archives de la liste
Chronologique Discussions
  • To: starpu-devel@inria.fr
  • Subject: [starpu-devel] Darts + Out of Core
  • Date: Thu, 3 Oct 2024 08:01:26 +0100
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=markshachkov@gmail.com; spf=Pass smtp.mailfrom=markshachkov@gmail.com; spf=None smtp.helo=postmaster@mail-lf1-f52.google.com
  • Ironport-data: A9a23:XAuW86P1LrOmuf/vrR1klsFynXyQoLVcMsEvi/4bfWQNrUpw0DJVx jZLDziGMq7bZDTyet51aIS3900PuMTSx9ViHXM5pCpnJ55ogZqcVI7Bdi8cHAvLc5adFBo/h yk6QoOdRCzhZiaE/n9BCpC48T8mk/vgqoPUUIbsIjp2SRJvVBAvgBdin/9RqoNziLBVOSvU0 T/Ji5OZYQbNNwJcaDpOt/vb8Ek34JwehRtB1rAATaAT1LPhvyJNZH4vDfnZB2f1RIBSAtm7S 47rpF1u1j6xE78FU7tJo56jGqE4aua60Tum1hK6b5Ofbi1q/UTe5EqU2M00Mi+7gx3R9zx4J U4kWZaYEW/FNYWU8AgRvoUx/4iT8sSq9ZeeSUVTv/B/wGXZU3r16cQzE3oHGrASqs9QXF9/r dAXfWVlghCr34pawZq+Q+how8AtdYzlYdlZtXZnwjXUS/0hRPgvQY2QvY4ejGp2354RW6uED yYaQWIHgBDoZhRVOUwXAZk+n+C2rnb6ejxc7lmSoMLb5kCKnFIvjuG2aIS9ltqiYuZuv221j 1r9pFvTOzIZBfCN7yWB7Sf57gPItWahMG4IL5Wj6vdwmEDWymENBRk+Tkq+ufD/i0ikWtsZJ VZ8x8Y1ha079UjuStekGhPl+jiLuRkTX9cWGOo/gO2Q9pfpD8+iLjBsZlZ8hBYO76fa6BRzv rNVt7sFxACDsYF5jVqY/7aQ6De8YG0bcDVEaigDQg8IpdLkpenfS/4JoslLSMaIYh/dQFkcA AxmaAAxgrwSiYgA0KDTEZXvnWe3vpaQJuIqzly/Y49mhz+VoKaqYoWp7R7Q6vMowEN1iLWel CBspvVyJ9ziwX1AeOJhjQnN8HyUCy65DQDh
  • Ironport-hdrordr: A9a23:PNyKUaC9l/YUSsXlHemh55DYdb4zR+YMi2TDtnoBLiC9F/bzqy nApoV56faZslYssRIb+OxoWpPwI080nKQdieIs1NyZLWzbUQWTXeVfBEjZrwEI2ReSygeQ78 hdmmFFZuHNMQ==
  • Ironport-phdr: A9a23:ghJclxeRbjTtrvmxHWUhpVxVlGM+XtTLVj580XLHo4xHfqnrxZn+J kuXvawr0ASRG9+Bs7kd0rSempujcFJDyK7CikxKSIZLWR4BhJdetC0bK+nBN3fGKuX3ZTcxB sVIWQwt1Xi6NU9IBJS2PAWK8TW94jEIBxrwKxd+KPjrFY7OlcS30P2594HObwlSizewb69+I A+ooQnPqsUajpZuJrswxxDUvnZGZuNayH9nKl6Ugxvy/MC88oJ9/S9Nofwh7clAUav7f6Q8U 7NVCSktPn426sP2qxTNVBOD6XQAXGoYlBpIGBXF4wrhXpjtqCv6t/Fy1zecMMbrUL07QzWi7 6NsSB/1lCcKMiMy/W/LhsBsiq9QvRSsrAF9zYHJeoGYLPVxcKPTc90ZWGRPQNpeWjdbDY+gd YYCFfYNMfpaooT7ulAArQG+BQ6pBO73zTFHnGX23a4n2Oo8EQHJxhAvH9INsHTTstX+KaAfU eWvw6nSzjXDdPNW1i3h54jIcRAhpu+MUKl/ccrU00YvFgfFgk+MpoziOjOYz+IAuHWU4OR8T +ygkXInqx1vrTi1wMchkojEi5wIx1zY9yh13Jg5KN2kRENnbtCpFJRduiCHOoV4Xs8vXX1lt SQnxrAIpZK2YjQGxZQmyhLCdfCKcYeF7w/lWe2MIjl4nGpodKyjixu260Stye3xWtOp3FtLr CdJiNnBum4L2hfO9MWHTuZ9/ly92TmRzQDd9+BEIEEqmqfDN5IsxKM7mIAJvkTZBCD2nV37j K+IeUUg/eil8+Hnba/npp+YLoN0jg/+Prk3lsyxAek0LBICX2ec+eS7273j+VP2TK9Wgf0xl 6nVqJHaJcIFqa6lGwJZzJov5hKlAzql0NkUh2QLIVNHdR6dj4XlJUnCIPXiAve+h1Ssni1rx /fDPrD5B5XCNGLDkLT6fbZ98UFT1AozzdNY55JKEbwBL/fzVVXwtNzcFBM2Lwu0w+P/BNV7z YwRQXiPDbOBMKPOrV+I4foiL/SUaI8PpDn9M+Ql5+LpjXIhgl8dYbOm3YEPaHClB/hpPluWY WTyjdcFCmoKpQo/TOnyiFKYSzJTZnCyX7g95j4hEo6mA53DFciRh+mawC6hBoATam1YB1SkE HHydozCVe1fRjiVJ5pEmyYHHYOhQoQh1haw/Fv/wqBkNerd8S0bsozL29185umVnhY3o28nR /+B2n2AGjkn1lgDQCU7ifgXSS1Vz16C1fI9mPlEDZlJ4PgPVA4mNJnaxug8CtboWwuHcM3aA E2+TICABjc8Bsk038dIe1x0TtCrlBPY3yOhA7wSiZSEAZU19uTX2H2ib91lxSP+3bI6x0IjX tMJMGSngqBl8A2GAofTkF6Znq2qdqMC9CHI/WaHi2GJuRIQSxZ+BIPCW31XfU7KtZL560fFG qepEqgiOxBdxNSqL6JLbpjtgwwDSqq5ftvZZG21liG7AhPgKqqkSo3sdi1d2SzcDBJBiAUP5 TOcMgN4AC69omXYBTgoFFT1Ykqq//Ms4HW8BlQ5yQ2HdSgDn/K85wIViPqASvgSwqNMuSEvr C9xFUq82NSeAsSJpg5odqFRKd0n51IP2WXcvg17dpuuSsIqzlsXaQdsv0rl1xZwFK1PlMErq DUhyw8zYaOU3VVddi+JiIjqM+6ySCG69xSuZqjKn1DGhYzOq+FftbJh9Qql4Vv6cyhqu29q2 NRUzXaGs5DDDQ5IFIn0Tl5y7R9x4bfTfig64YrQk3xqK6i99DHYiLdLTKMozAite9BHPeaKD gj3RocfDtKtM+wjkFiqaQwsM+Vb9apyNMSjPajjuubjLKN7kTSqgH4SqoV0yEGX9yN3Su3Pw b4KxviZ2k2MUDK23zLD+ojn3ItDYz8VBG+2zyPpUZVQaqNFdoEOEW6yIsezy72SnrbVUmVDv B6mDlICgoqyfAaKKkb61ktW3FgWpnqunW25ySZ1mncntPjX0CvLyuXkPB0JXwwDDGxrl1T3I YG/j9MdQmCnagEokF2u4kOyy6VApat5JnXeWg8SJ3mwfzwkC/Xv8OfYK8dUoIslqyBWTPixb TX4Avbmrh0W3jmiV2pSyTYndi2775Dwnhh0kmWYfz54qHvUf901xA+KvoSNA64MmGNYG28l0 2qyZBD0JdSi8NSKmo2Wt+m/UzjkTZhPaWzxyojGsiKn5GpsCBn5nvapm9ShHxJptE2zn9RsS yjMqw7xJ4fx0KHve+duZEpzBFb368l9BKlxl4IxgNcb3n1Q1fD3tTIX1Hz+N9lWw/e0aXMXR iULytXV4w/78EJmJ3ONgYn+Uz/Op6kpL8n/aWQQ1CUn6slMA6rB971Ikxx+pV+gpB7Qa/xwz X8NjOEj43kAj6QVqRIgm2+DV6sKExASbkmO31yYqsqzp6JNaCOzfKisgQBgyMu5AujKoxkAC i2kPM5zRWkqspo5aBWWjDXy8t22JoWWN4lI8ETKy1GYyLEETfB53vsS2Xg5ZySk5Sdjk6hjy kY2lZCi4NrZdSM3oPP/UkYebnqvP4sS4m2/0vwYx5rQhtH1WM0mQ2VuPtOgTOr0Qm1O8629a kDWVmV78ynTGKKDT1bHuAE/8C2JQ9bzcCvObHgBkYc7G0LbfR0DxlhSBHJjwPtbXkir3JCzK h8ooGBMoAei+l0Ujbs3fxjnDjWF/VnuN2dyEcnFakIRt1AK5l+JY5bHsKQpRHAepcfn9EvUe wn5L0xeBGUNECRoHnjFOb+jrZnF+umcXK+lKufWJK+JoqpYXuuJwpSm1s1n+SyNP4OBJCsqC fpzwUdFUX1jfqaR0zwSVywakT7MZM+HtV+9/CNwtMW27PXsXkrm+4KOD7JYNdgn9QqxhO+PM OuZhSAxLjg9tNtE3XjT1L0Wx0IfkQlrfjipVLAO7GvDEfiWlahQABoWLSh0MYoA7q4x2BVMJ d+Oit7x0e0d7LZ9AFNEWFr938CxMJZSciftaRWeWhnNae7VQF+Di9v6aq69V7BK2eBdthnq/ C2eD1emJDOI0T/gSxGoN+hIyiCdJh1X/o+nIXMPQSDuSszrbhqjPZp5lzozlPcxj2nJLm4VO jh/dF1lobiZ7CceifJ6UT8kjDItPayfliCV4vONYI4RquduCz9omvhy5X07z/5R4ngBSqEv3 iTVqdFqrhetlezFmV8FGFJe7z1MgoyMp0BrP67Uo4JBVXjz9xUI9WyMCh4OqrON6/XqsqFUj 9zBzef9dW0E/NXT8s8RQcPTLZDfWJLOGRXsET/QSgACSGzyXYk6r0NYmfCWsHaSq8piwqU=
  • Ironport-sdr: 66fe415c_aFo5ZjjTnAXSUQVCBempGcLOjiu664ym7w5UOmjmuCPkXMC ohyiHNniJFYtJZacC2AMa4LkCohbgUIt7WkpPkQ==
Hello! Thank you for your work on StarPU.
I am trying to evaluate if i can use StarPU runtime in order to improve performance of computation that involves usage of CPUs, GPUs and OutOfCore. I have encountered an issue with DARTS scheduler: it appears that the compute progress stops/hangs when host memory limit is reached and eviction to disk begins. On the contrary, using DMDA scheduler allows computation to finish.
My question: is DARTS scheduler designed/implemented to be compatible with OutOfCore (eviction to disk) mechanism?
Best,
Mark Shachkov
Haut de le page
