Archives de la liste
Re: [starpu-devel] [Perl: loadable library and perl binaries are mismatched]
Chronologique Discussions
- To: Maxim Abalenkov <maxim.abalenkov@gmail.com>
- Cc: starpu-devel@inria.fr
- Subject: Re: [starpu-devel] [Perl: loadable library and perl binaries are mismatched]
- Date: Tue, 5 Nov 2024 09:46:42 +0100
- Authentication-results: mail2-relais-roc.national.inria.fr; dkim=none (message not signed) header.i=none; spf=SoftFail smtp.mailfrom=samuel.thibault@inria.fr; dmarc=fail (p=none dis=none) d=inria.fr
- Organization: I am not organized
Hello,
Maxim Abalenkov, le mar. 05 nov. 2024 08:41:45 +0000, a ecrit:
> HELP2MAN starpu_env.1
> Encode.c: loadable library and perl binaries are mismatched (got handshake
> key
> 0x10200080, needed 0xfb80080)
> Can you please tell me, how do I point StarPU to a specific Perl
> installation that I want to use? Thank you and have a great day ahead!
StarPU by itself doesn't use perl. From your log it's apparently the
help2man command which does, so you need see inside that coode.
Samuel
- [starpu-devel] [Perl: loadable library and perl binaries are mismatched], Maxim Abalenkov, 05/11/2024
- Re: [starpu-devel] [Perl: loadable library and perl binaries are mismatched], Samuel Thibault, 05/11/2024
