Archives de la liste
Re: [starpu-devel] Fw: Question about Properly Unregister Data for a Custom Interface
Chronologique Discussions
- To: Xinbo Li <lix34545@myumanitoba.ca>
- Cc: "starpu-devel@inria.fr" <starpu-devel@inria.fr>
- Subject: Re: [starpu-devel] Fw: Question about Properly Unregister Data for a Custom Interface
- Date: Wed, 23 Apr 2025 01:45:14 +0200
- Authentication-results: mail3-relais-sop.national.inria.fr; dkim=none (message not signed) header.i=none; spf=SoftFail smtp.mailfrom=samuel.thibault@inria.fr; dmarc=fail (p=none dis=none) d=inria.fr
- Organization: I am not organized
Xinbo Li, le mar. 22 avril 2025 19:28:39 +0000, a ecrit:
> Sending this question to the mailing list for the record.
And sending the answer too.
> I do have an allocate_data_on_node method implemented as
> static starpu_ssize_t rkmatrix_allocate_data_on_node(void *data_interface,
> unsigned node)
> std::cout << "Allocate Data called.\n";
> struct starpu_rkmatrix_interface *rkmatrix_interface =
> (struct starpu_rkmatrix_interface *) data_interface;
> // prkmatrix rkmat = rkmatrix_interface->rkmat;
> /* Allocate memory for the rkmatrix struct */
> prkmatrix rkmat_new = NULL;
> double *a_real = NULL; double *a_imag = NULL;
> double *b_real = NULL; double *b_imag = NULL;
> starpu_ssize_t requested_memory_a = 0, requested_memory_b = 0;
> starpu_ssize_t rk_struct_size = sizeof(rkmatrix);
> rkmat_new = (prkmatrix) starpu_malloc_on_node(node, rk_struct_size); //
> a
> new rkmatrix pointer
> if (!rkmat_new)
> goto failure;
> *rkmat_new = *rkmatrix_interface->rkmat; // copy the meta data (data
> pointers will also be
> // copied but will be reset shortly)
> rkmatrix_interface->rkmat = rkmat_new;
So this is allocated in rkmatrix_allocate_data_on_node, and
not in rkmatric_data_register, so it should be released in
rkmatrix_released_data_on_node, and not in rkmatric_data_unregister.
> /* Allocate memory for the data members in rkmat */
> requested_memory_a = rkmatrix_interface->rkmat->rows *
> rkmat->k * sizeof(rkmatrix_interface->rkmat->a[0]);
> requested_memory_b = rkmatrix_interface->rkmat->cols *
> rkmat->k * sizeof(rkmatrix_interface->rkmat->b[0]);
> a_real = (double*) starpu_malloc_on_node(node, requested_memory_a);
> if (!a_real)
> goto failure;
> a_imag = (double*) starpu_malloc_on_node(node, requested_memory_a);
> if (!a_imag)
> goto failure;
> b_real = (double*) starpu_malloc_on_node(node, requested_memory_b);
> if (!b_real)
> goto failure;
> b_imag = (double*) starpu_malloc_on_node(node, requested_memory_b);
> if (!b_imag)
> goto failure;
> /* update the data properly in consequence */
> rkmatrix_interface->rkmat->a = a_real;
> rkmatrix_interface->rkmat->a_imag = a_imag;
> rkmatrix_interface->rkmat->b = b_real;
> rkmatrix_interface->rkmat->b_imag = b_imag;
> return 2*(requested_memory_a+requested_memory_b) + rk_struct_size;
> failure:
> return -ENOMEM;
> Would this method be called on the nodes who do not have the data after the
> registration somehow?
StarPU calls it when it needs to have the data allocated somewhere, and
calls release when it's not useful any more, or on registration, before
calling the unregister_data_handle.
> Also, the reason I implemented an unregistration method and called it
> explicitly is because calling starpu_data_unregister will always seg fault
> for
> some reason, so I thought it might be easier to have a explicit call to the
> unregistration method.
I don't understand what you mean. It's starpu_data_unregister
which shall call the unregister_data_handle method. Not calling
starpu_data_unregister means you'll not synchronize anything, leak all
starpu internal buffers etc.
Samuel
- [starpu-devel] Fw: Question about Properly Unregister Data for a Custom Interface, Xinbo Li, 22/04/2025
- Re: [starpu-devel] Fw: Question about Properly Unregister Data for a Custom Interface, Samuel Thibault, 23/04/2025
