Accéder au contenu.
Menu Sympa
typographie - Re: [membres-apiiq]: Probl�mes du format PDF, format suppos�ment � toute �preuve
Archives de la liste
Chronologique Discussions
  • To: sc22wg20 AT dkuug.dk
  • Subject: Re: [membres-apiiq]: Problèmes du format PDF, format supposément à toute épreuve
  • Date: Fri, 20 Nov 1998 11:10:35 -0600
Info.
Alain
______________________________________
>Date: Fri, 20 Nov 1998 10:58:47 -0500
>From: Daniel Amyot
><damyot AT csi.uottawa.ca>
>Organization: University of Ottawa
>X-Accept-Language: en,fr-CA
>To: "Winkler, Arnold F"
><Arnold.Winkler AT unisys.com>
>CC: Alain Labonté
><alb AT sct.gouv.qc.ca>
>       supposément Ã  toute Ã©preuve
>Hello,
>"Winkler, Arnold F" wrote:
>> Thanks,
>you're welcomed.
[Arnold] :
>> Spoke to Alain, and I am following your advise.
>> I was able to create a correct output by some strange other means -
>> copying the document with exception of the very last paragraph mark and
>> then create pdf from this new document.
>> The document is now OK (at least as much as I checked).
[Daniel] :
>I was amazed to see that you were able to generate something as good as the
>document I read on the Web  with Word and the PDF Writer. Now that you tell
>me how you did it, this makes me wonder whether the problem is related to the
>FastSave option in word. When you copy the content of a document and paste it
>in an empty one, the only difference with the first document is related to
>the FastSave information (from previous versions).
>In any case, according to my experience, the Distiller seems to be a safer
>way to generate PDF files (from any application).
>Regards,
>Daniel.
Haut de le page
