Archives de la liste
- To: typographie AT irisa.fr
- Subject: Re: E et _
- Date: Fri, 27 Aug 1999 16:18:41 +0200
- Organization: IRISA, Campus de Beaulieu, 35042 Rennes Cedex, FRANCE
Olivier Noyelle wrote:
> Chers tous,
> Quelqu'un connait-il l'origine, le nom, la signification, l'utilisation qui
> est faite des signes suivants :
> 1/ Une sorte de « e » énorme sur les bouteilles de parfum et autres et qui
> veut dire « contenance approximative » si je ne m'abuse.
Chuck Bigelow (que j'aime beaucoup, et je le dis sans casque) a écrit un
article sur la typo des parfums. Voici ce qu'il me dit à ce sujet :
> But I do not recall the "E" symbol when I did the research
> 9-10 years ago.
> I will look at some bottles of French perfume to see if
> I can find the "E". (When I did the research on perfume
> typography, of course I had to buy many bottles of perfume,
> which I gave to Kris. She still has many of them, so it will
> be easy for me to research.)
> There is a standard symbol "e", which looks like a large,
> sans-serif, thin, lower-case "e". This means "estimated".
> It is given Unicode code value 212E. You will see an
> example of it in the font "Lucida Sans Unicode" in the
> 1994 RIDT paper by me and Kris, which you composed for
> typesetting. I did not like our design, but Microsoft
> insisted that it have the same ugly look as the usual
> German version of it. In future fonts, we will re-design it.
> This symbol is used on European food packages, candy bars,
> and other products to signify estimated weight or estimated
> volume.
> [a few moments in time pass]
> Eureka! I just checked a few bottles of French men's colognes.
> An older bottle of Guerlain "Eau de Cologne Imperial" does
> not have the "e", but a small bottle of Annick Goutal
> "Sables" says on the small label on back:
> "e 30 ml - 1 fl. oz."
> Here, the "e" is a large lower-case letter, enlarged to
> the capital height or figure height. This "e" is from the
> same font as the rest of the little label, a kind of
> Garamond style, rather than the very ugly sans-serif
> commonly used in some countries. I approve of the French
> perfumers having better typographic taste.
> So, perhaps today the "e" = "estimated" symbol is now
> used to signify volume on perfume labels.
Ça me rappelle ma consternation d'enfant quand je voyais sur les pots de
confiture ou autre :
poids net : environ 500 grammes !
Jacques André
Irisa/Inria-Rennes, Campus de Beaulieu, F-35042 Rennes Cedex,
France
Tél. : +33 2 99 84 73 50, fax : +33 2 99 84 71 71, email :
jandre AT irisa.fr
- E et _, Olivier Noyelle, 26/08/1999
- Re: E et _, Jacques Andre, 26/08/1999
- Re: E et _, Jacques Andre, 27/08/1999
