Accéder au contenu.
Menu Sympa
typographie - l'alignement optique d'InDesign
Archives de la liste
Chronologique Discussions
  • To: 'TypoFrançaise' <typographie AT irisa.fr>
  • Subject: l'alignement optique d'InDesign
  • Date: Tue, 21 Sep 1999 12:16:50 -0600
Salut!
A slight (temporary) detour from "Révisions":
Has anyone tried out the optical alignment feature in InDesign yet, and did
it perform as expected? I tried it earlier today, and was surprised that the
composition did not always match what I thought should happen -- for
example, "O" did not hang slightly outside the left margin when at the start
of a line.  Shouldn't the "O" move to the left more? I haven't had enough
time to determine whether the behavior I'm seeing is the algorithm used, or
the parameters I used in the style sheet (or if what I expect is not
typographically correct!). Has anyone else played with this yet?
Rob Keeble
Haut de le page
