Archives de la liste
- To: typographie AT irisa.fr
- Subject: guillemets et chicago manual of style
- Date: Mon, 2 Dec 2002 10:53:26 +0100
- Comments: Sender has elected to use 8-bit data in this message. If problems arise, refer to postmaster at sender's site.
- Priority: normal
J'ai trouvé ça sur la FAQ du /Chicago manual of style/ :
In what is sometimes called the British style, only those punctuation points
that appeared in
the original material should be included within the quotation marks; all
others follow the
closing quotation marks. This system works best with single quotation marks.
(The British
tend to use double quotation marks only for quotations within quotations.)
Je ne sais pas ce que vaut cette règle mais ça semble confirmer qu'il s'agit
d'un problème
graphique : si le guillemet fermant chasse peu, il est moins gênant de placer
la ponctuation
basse après...
- guillemets et chicago manual of style, Nils Gesbert, 02/12/2002
