Accéder au contenu.
Menu Sympa
typographie - Re: [typo] Logiciels PAO
Archives de la liste
Chronologique Discussions
  • To: typographie AT listes.irisa.fr, Philippe MICHEL <philippe AT michel.fdn.fr>
  • Subject: Re: [typo] Logiciels PAO
  • Date: Fri, 11 Jan 2019 00:08:50 +0100
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=yoann AT le-bars.net; spf=None smtp.mailfrom=yoann AT le-bars.net; spf=Pass smtp.helo=postmaster AT mailincloud.com
  • Dkim-filter: OpenDKIM Filter v2.11.0 mailincloud.com BA68D21531
  • Ironport-phdr: 9a23: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
Salut à tous !
Le 11/01/2019 à 00:01, Philippe MICHEL a écrit :
> Ensuite, l'un ou l'autre, sauf cas très particuliers, je ne vois pas de
> différence à l'usage. Peut être que LuaLaTeX est moins souple & bloque
> plus facilement sur de petites erreurs ?
J’ai pu utiliser tous les packages avec LuaLaTeX. En revanche, XeLaTeX
n’est pas compatible avec certains packages. Par exemple, le package
multimédia, lequel, par exemple, me sert à insérer des vidéos dans mes
présentations, ne peut pas être utilisé avec XeLaTeX. C’est ce problème
de compatibilité qui m’a fait passer de XeLaTeX à LuaLaTeX.
En définitive, en plus d’un plus grand nombre de packages compatibles,
je trouve LuaLaTeX plus souple, au contraire.
À bientôt.
Yoann LE BARS
http://le-bars.net/yoann/
Diaspora* :
ylebars AT framasphere.org
Archives gérées par MHonArc 2.6.18.
Haut de le page
