Archives de la liste
- From: Emmanuel Curis <emmanuel.curis AT parisdescartes.fr>
- To: typographie AT listes.irisa.fr
- Subject: Re: [typo] Logiciels PAO
- Date: Fri, 11 Jan 2019 11:58:22 +0100
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=emmanuel.curis AT parisdescartes.fr; spf=None smtp.mailfrom=curis AT pharmacie.univ-paris5.fr; spf=None smtp.helo=postmaster AT mataram.parisdescartes.fr
- Ironport-phdr: 9a23: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
Je pensais que l'on pouvait avoir des textes en UTF-8 dès le latex de
base (pas trop vieux sans doute), avec
\usepackage[utf8]{inputenc}
et donc dans n'importe quelle variante de tex ?
Bon, ça ne permet pas encore d'entrer autre-chose que les caractères
accentués, par exemple des tirets, guillemets, caractères grecs...
Emmanuel, qui ne connaît rien aux variantes XeLatex, Lualatex, Miktex
et se contente d'utiliser la version fournie avec sa distribution linux...
On Thu, Jan 10, 2019 at 11:27:20PM +0100,
thuwart AT proximus.be
wrote:
« Pour ceux que cela intéresse...
« Après moult réflexions, j'ai opté pour LuaLaTeX quand la bataille contre
XeLaTeX faisait encore rage.
« Et il me semble que LuaLaTeX fait aujourd'hui consensus, et que XeLaTeX
finirait par disparaître?
« LuaLaTeX permet enfin les entrées directement en unicode, ce qui est enfin
plus facile pour les
« caractères accentués. LuaLaTeX a aussi un moteur lua - qui est un langage
de programmation assez
« simple - qui permet d'intercepter certaines commandes et de générer une
sortie différente (perso,
« je n'ai jamais eu besoin de lua).
https://tex.stackexchange.com/questions/126206/why-choose-lualatex-over-xelatex
(attention, la
« discussion a été ouverte il y a un siècle: 5 ans).
« Il existe de nombreux ouvrages (le plus souvent en anglais) sur LaTeX dans
la boutique à Bezos ou
« (probablement sur commande) chez votre libraire préféré. J'avais commencé
avec la 3ème édition
« de https://www.amazon.com/dp/0321173856/ (bon rapport qualité/prix pour
débuter).
« Beaucoup de cours à droite ou à gauche et des sites de niveaux divers fort
utiles, comme :
« https://www.latex-tutorial.com/tutorials/
« ou http://www.texample.net/tikz/examples/
« Et oui, l'édition d'un roman quelconque (comprendre: sans graphiques
compliqués) est un jeu d'enfant
« avec quelques instructions de base. Les notes de bas de page, l'insertion
de pages blanches avant un
« nouveau chapitre, le titrage, les couleurs, tout cela peut être (assez
facilement) automatisé. En principe
« (je dis bien "en principe") le code est pérenne et portable et devrait
donner des résultats stables entre
« deux versions du logiciel.
« -----Message d'origine-----
« De :
typographie-request AT listes.irisa.fr
[mailto:typographie-request AT listes.irisa.fr]
De la part de Yoann LE BARS
« Envoyé : jeudi 10 janvier 2019 21:59
« À :
typographie AT listes.irisa.fr;
Jean-Pierre Messager
<jpierremessager AT gmail.com>
« Objet : Re: [typo] Logiciels PAO
« Salut à tous !
« Le 10/01/2019 à 16:50, Jean-Pierre Messager a écrit :
« > Il existe déjà un ouvrage similaire disponible sous licence creative
« > commons : (Xe)LaTeX appliqué aux science humaines :
« > https://geekographie.maieul.net/95
« > http://tug.ctan.org/info/latex-sciences-humaines.pdf
« Cependant, il a à mon sens un petit problème : il se base sur XeLaTeX
alors qu’aujourd’hui je conseille plutôt LuaLaTeX.
« Cela dit, c’est un très bon ouvrage et Maïeul ROUQUETTE intervient
sur la liste du GUT.
« À bientôt.
« Yoann LE BARS
« http://le-bars.net/yoann/
« Diaspora* :
ylebars AT framasphere.org
« La liste Typo — discussions typographiques
« Les archives : https://sympa.inria.fr/sympa/arc/typographie
« Désabonnement :
<mailto:sympa_inria AT inria.fr?subject=unsubscribe%20typographie>
Emmanuel CURIS
Page WWW: http://emmanuel.curis.online.fr/index.html
- [typo] Logiciels PAO, jtombeur, 10/01/2019
- Re: [typo] Logiciels PAO, Jean-Pierre Messager, 10/01/2019
- Re: [typo] Logiciels PAO, Eric Guichard, 10/01/2019
- Re: [typo] Logiciels PAO, Yoann LE BARS, 10/01/2019
- RE: [typo] Logiciels PAO, thuwart, 10/01/2019
- Re: [typo] Logiciels PAO, Philippe MICHEL, 11/01/2019
- Re: [typo] Logiciels PAO, Yoann LE BARS, 11/01/2019
- Re: [typo] Logiciels PAO, Emmanuel Curis, 11/01/2019
- Re: [typo] Logiciels PAO, Eddie Saudrais, 11/01/2019
- Re: [typo] Logiciels PAO, Thierry Bouche, 11/01/2019
- Re: [typo] Logiciels PAO, CLS, 10/01/2019
- Re: [typo] Logiciels PAO, Pymnet, 10/01/2019
- <Suite(s) possible(s)>
- Re: [typo] Logiciels PAO, jtombeur, 11/01/2019
- RE: [typo] Logiciels PAO, thuwart, 11/01/2019
Archives gérées par MHonArc 2.6.18.
