Accéder au contenu.
Menu Sympa
typographie - Re: [typo] L'IN Groupe
Archives de la liste
Chronologique Discussions
  • To: typographie AT listes.irisa.fr
  • Subject: Re: [typo] L'IN Groupe
  • Date: Thu, 24 Jan 2019 15:14:13 +0100 (CET)
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=jtombeur AT cegetel.net; spf=None smtp.mailfrom=jtombeur AT cegetel.net; spf=None smtp.helo=postmaster AT smtp26.services.sfr.fr
  • Ironport-phdr: 9a23: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
A‌h ben mince alors... Pendant des années j'ai utilisé et popularisé kbdfrac.exe
(au passage, j'avais confectionné le visuel qu'on trouve sur le site de téléchargement initial :
http://users.sfr.be/denis.liegeois/kbdfrac.htm)
Là, cela me semble encore plus costaud...
(en nb. de raccourcis).
J'hésite un peu à adopter... J'ai l'habitude du clavier étendu kbdfrac depuis 2000...
M'enfin, hormis les tirets qui ne sont pas aux mêmes emplacements de touches, cela se recoupe...
Donc, je vais au moins essayer.
Pour être franc, je ne vois pas trop l'intérêt d'avoir Î ou î, et les ê, â, &c., et divers combinaisons avec le tréma.
Pas mauvais d'avoir les copyright en C
Le point médian (pour l'écriture inclusive ; marche des typos et cor. helvètes) est bien en . (point) ?
Le truc de départ de la discussion, c'était les Minion Pro et l'apostrophe...
Les approches sont trop riquiqui, et flemme de réinstaller un logiciel de création de car. pour y remédier (difficultueusement, tout oublié du « bonheur » de bidouiller des fontes). Et je n'ai jamais pu m'y retrouver avec MSKLC (MS Keyboard Layout Creator).
Un colistier m'a aimablement signalé qu'avec InDesign on pouvait rendre solidaire toute une ligne (ou quelque chose comme cela, donc, l'espace ultra-fine que j'insère entre la lettre et l'apos. des Minion Pro devient de fait insécable, si j'ai bien tout compris).
Cela étant (chut, surtout pas le répéter, c'est je crois, illégal : si quelqu'un·e avait ainsi bidouillé les approches des Minion Pro et me passait ses polices, merci ; croix de bois, croix de fer, je remercierai et la fermerai). ;-)
Pour celles et ceux qui débutent total, je signale que À s'obtient avec AltGr+è puis A-cap, soit Maj+A (Windows). Même chose pour É avec é (Ẽ) ou m'illusionnerais-je ? Là, éclairez-moi, je vois deux accents au-dessus du é-cap... Eh, hé, non, c'est avec l'apostrophe... Ou 144 (clav. num.).
Sinon, j'avais en mémoire tous les codes Alt+0x du clavier numérique (sauf que, là, il faut que je revienne à un clavier étendu...)...
L'intérêt, par rapport à kbdfrac, de ce clavier fr., c'est bien sûr la dimension « internationale ».
(roumain, esp., all.).
Juste une remarque sur le pdf, troisième visuel...
D'une part, le profane (je suis redevenu béotien, oublié plein de trucs, autant que mes rudiments de russe laborieusement acquis) ne doit pas trop piger tous ces Ukekchoz (Unicode ? j'imagine)...
ssharp, pas trouvé (j'ai vaguement cherché ce que cela signifie).
Le truc serait peut-être de déporter les mentions comme questiondown (et autres qui débordent) sur le pourtour avec un trait en bleu (ou autre couleur). Il faut vraiment agrandir pour décrypter les quotemarks...
Cela étant, formidable travail, et je télécharge clavier_fr-oss.zip et ossc (le second sera installé jusqu'à changement de clavier).
Hors-liste : pour qui fait des sudokus, voir http://mjulier.free.fr/sudoku_lisez_moi.html (rigolo).
Retour liste : j'ai donc kbdfrac... Et pendant longtemps, j'avais le visuel à portée de main...
À présent, la v.10 (voire la 8.x) de MSWindows permet d'afficher un clavier visuel (pour saisie en mode tablette)... J'imagine que si vous changez le pilote standard, la disposition du nouveau (kbdfrac, oss, ossc, bepo, je ne sais quoi encore), le clavier visuel vous affichera les bonnes touches du nouveau pilote...
En tout cas, pour kbdfrac, en mettant ALT et CTRL en surbrillance, je visualise les car.
De : "Thomas Savary"
A : typographie AT listes.irisa.fr
Envoyé: jeudi 24 janvier 2019 12:27
Objet : Re: [typo] L'IN Groupe
mercredi 23 janvier 2019, à 22:45:31 CET, jtombeur AT cegetel.net a écrit :
> Ex. : difficile d'insérer aisément une
> espace ultra-fine ou fine après ou avant des guilles...<br> Surtout pour un
> texte mis en ligne (hors PDF ou autre...).
Pour l’espace fine insécable, Alt. Gr. + V (avec la disposition de clavier « fr‑oss », alias « Français (variante, touches mortes Sun) » dans les distributions GNU-Linux ou BSD en français. Cette disposition est à la disposition des windowsiens à l’adresse suivante : http://mjulier.free.fr/clavier/, où l’on trouvera également la carte de ladite disposition fr‑oss.
Cordialement,
Thomas Savary
Le Grand Plessis
F-85340 L’Île-d’Olonne
Tél. 06 22 82 61 34
www.compo85.fr
www.correctionpro.fr
La liste Typo — discussions typographiques
Les archives : https://sympa.inria.fr/sympa/arc/typographie
Désabonnement : <mailto:sympa_inria AT inria.fr?subject=unsubscribe%20typographie>
Archives gérées par MHonArc 2.6.18.
Haut de le page
