Archives de la liste
- To: typographie AT inria.fr
- Subject: Re: [typo] Didot de labeur
- Date: Sat, 6 Feb 2021 14:02:11 +0100
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=thlinard AT gmail.com; spf=Pass smtp.mailfrom=thlinard AT gmail.com; spf=None smtp.helo=postmaster AT mail-wm1-f47.google.com
- Ironport-phdr: 9a23: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
Bonjour,
Pour le problème des déliés trop fins, une Didone avec un axe optique peut être la solution, comme celle-ci :
https://indestructibletype.com/Bodoni.html
Ou celle d'Hoefler :
https://www.typography.com/fonts/didot/
La question est d'ailleurs traité dans le « How to use » :
https://www.typography.com/fonts/didot/how-to-use
Sur le blog d'Identifont (à « Trianon »), par Stephen Coles :
http://blog.identifont.com/show?WUL
Et dans I Love Typography, par Kris Sowersby :
https://ilovetypography.com/2008/01/22/why-bembo-sucks/
Et Tim Ahrens et Shoko Mugikura ont consacré un livre au sujet :
https://justanotherfoundry.com/size-specific-adjustments-to-type-designs
Cordialement,
Thomas Linard
Bonjour, la liste ! Dans la perspective de proposer des facsimilés partiels de classiques du dix-neuvième siècle et de la première moitié du siècle dernier, je suis à la recherche d’une didot comme police de labeur. La Didot de Linotype (Frutiger) est parfaite pour la titraille, mais les déliés en sont bien trop fins pour qu’elle puisse être utilisée pour le texte courant. Il existe bien la Linotype Didot eText, plus grasse, mais je trouve qu’elle chasse un peu trop. https://www.myfonts.com/fonts/linotype/didot-etext-pro Parmi les polices libres, on trouve la Theano, pas trop mal mais dépourvue d’italique. https://www.fontsquirrel.com/fonts/theano-didot Quelqu’un connaîtrait-il une police susceptible de convenir ? Cordialement, Thomas Savary 1 le Grand-Plessis F-85340 L’Île-d’Olonne Tél. 06 22 82 61 34 https://compo85.fr/ https://correctionpro.fr/
- [typo] Didot de labeur, Thomas Savary, 06/02/2021
- Re: [typo] Didot de labeur, Jacques ANDRÉ, 06/02/2021
- Re: [typo] Didot de labeur, Thomas Linard, 06/02/2021
- Message indisponible
- Re: [typo] Didot de labeur + Tolstoï, Thomas Savary, 08/02/2021
- Re: [typo] Didot de labeur + Tolstoï, Jacques ANDRÉ, 09/02/2021
- Re: [typo] Didot de labeur + Tolstoï, Thomas Savary, 09/02/2021
- Re: [typo] Didot de labeur + Tolstoï, Benoît Leraillez, 09/02/2021
- Re: [typo] Didot de labeur, infondsv, 26/02/2021
