Archives de la liste
- To: Jacques Melot <jacques.melot AT isholf.is>
- Cc: typographie AT inria.fr
- Subject: Re: [typo] Usage des accents
- Date: Wed, 28 Jul 2021 14:28:03 +0200
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=didier AT didierverna.net; spf=None smtp.mailfrom=didier AT didierverna.net; spf=None smtp.helo=postmaster AT smtp1-g21.free.fr
- Face: iVBORw0KGgoAAAANSUhEUgAAADAAAAAwBAMAAAClLOS0AAAAFVBMVEVfISi7uXMbIRbQ0c2x aVhqe1lYchlOh6WjAAACeklEQVQ4jVWUQdPiIAyGI9N6lgU8d5mv3BncPbcjehY1nLfdIf//J2xo q35LZ+rIw0uSN1GwvPq7XT6M8kFuC+rOzx8L2PF3L2VY1gqqonsiYlL/KXb3zrYaEUA0Sm0KaerB zqKM8XITXXop+JRF7G2qx7wWfVCfGAVdu14Q9EuygmT+biAcdvW9gWmWr/3g4bvi+HjtS3VI/g3w l3rtS3VqvynwLeDab+c3mKZ3BC3lkN4gvUJ4WcHuE+MF9Cgr+BT4+IRgsEQH0WbC8yYYoD3LoV8V k5lRBe9VON1Y3chhcQWgJDJKXkQTzI0tZWAfng0QvcxHpfwFgo4bWBSMSz4HCV0wnAnAyFd5z6CX mB+n9jaGg+iGCuxXVThbiD2sM2CGUTPQsFtsd7lkroM7OIDi/jJoRsOgHIk35VLGKEcdY8MtSUCI tHl4gtHrOEYYtMngiMoGdGx8bGIc4mgIiLDUCeGa+BK+iEHTmAJImZbR4TJqrhXENh0hZzZxAVwD sCgO1+cej0DSbOAk2BAWXOOY0QBNmWhthu5YcuUQpmCGkikXtY3UIskFUWbOav7T1/J8rEGaa7wk SjgzoLkQd+mp2CiAa3yOSJbqVQvgDvoqoWtCcgwoO5ftg4ffx2u9q0ThyM4wu0Ib0EuQ9uI4zzt7 VZ+nVHUMFwmnacsMuZq1gsDt7uDrlmdH+wookX5WoEWdHyAGAshazmo6MPF1LLsIaN295+D1wPS7 Q6zzZqGBVvQMsput5R4Kuy5o7H7GmSDb3Lo8hcO630G0gOXOWXXYt5iCXyXsr+1KuXPlhf8aHP8k zAaaoaNCM7DHPMs8WH6wVtQCtXAT2X/K7NQKPk4fSgAAAABJRU5ErkJggg==
- Ironport-hdrordr: A9a23:+bOwr6PNmtrgRMBcTv6jsMiBIKoaSvp037AO7TEVdfUzSL39qynOpoV56faaskd2ZJmt8ersBEH9Kkm3yXcY2+cs1M6ZMDUO21HYS72Kk7GI/9S6IULDH4dmvM9dms5FaOEYZmIK7/oSjjPYLz9Z+qj/zJyV
- Ironport-phdr: A9a23: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
- Mail-copies-to: never
Jacques Melot <jacques.melot AT isholf.is> wrote:
> Le QWERTZ présente le gros inconvénient de ne pas pouvoir être utilisé
> par les dactylographes déjà formés sans nécessiter un nouvel
> apprentissage qui se verra compliqué par la nécessité de dominer les
> anciens réflexes.
C'est le problème général des agencements de clavier « en dur », qui
ne seront jamais adaptés qu'à peu près à une langue à la fois... À titre
personnel, je trouve vraiment dommage que le concept de « méthode de
saisie », assez connu chez les informaticiens, et que l'on trouve par
exemple sous l'éditeur de texte Emacs, ne soit pas plus répandu.
Voici comment sous Emacs, et sur un clavier QWERTY, j'obtiens les
accents (y compris dans cet email):
- e ' -> é
- E ' -> É
- c , -> ç
etc.
Pour obtenir e', on double l'accent et c'est tout: e ' '.
C'est très facile à mémoriser et ça devient très vite un réflexe.
Dans ce cas, il s'agit d'une méthode postfixe, mais il existe la même
chose en préfixe (p.ex. on tape ' e au lieu de e ').
Pour taper de l'Espagnol, je change de méthode, et j'obtiens en plus,
par exemple, n ~ -> ñ. Pas besoin de changer de clavier à chaque
langue...
¡En Seguida! -- New album: https://www.didierverna.com/records/en-seguida.php
Available on all digital platforms now!
Lisp, Jazz, Aïkido: http://www.didierverna.info
- Re: [typo] Usage des accents, (suite)
- Re: [typo] Usage des accents, Jacques André, 27/07/2021
- Re: [typo] Usage des accents, Jacques Melot, 27/07/2021
- Re: [typo] Usage des accents, Amalric Oriet, 27/07/2021
- Re: [typo] Usage des accents, Marion Gevers, 28/07/2021
- RE: [typo] Usage des accents, diconoma, 27/07/2021
- Re: [typo] Usage des accents, Benoît Leraillez, 27/07/2021
- Re: [typo] Usage des accents, Jacques Melot, 28/07/2021
- Re: [typo] Usage des accents, Benoît Leraillez, 28/07/2021
- Re: [typo] Usage des accents, Didier Verna, 28/07/2021
- Re: [typo] Usage des accents, Nicolas Ribeyre, 28/07/2021
- Re: [typo] Usage des accents, jm, 28/07/2021
