Objet : Discussion list for Belenios
Archives de la liste
- From: Anthony PERRIN <anthony.perrin54 AT gmail.com>
- To: belenios-discuss AT inria.fr
- Subject: [belenios-discuss] récupération des code de vote
- Date: Wed, 29 Sep 2021 10:36:02 +0200
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=anthony.perrin54 AT gmail.com; spf=Pass smtp.mailfrom=anthony.perrin54 AT gmail.com; spf=None smtp.helo=postmaster AT mail-vs1-f45.google.com
- Ironport-hdrordr: A9a23:o1TIOKAm/uZGIu3lHemh55DYdb4zR+YMi2TDtnoBLiC9F/bzqynApoV56faZslYssRIb+OxoWpPwI080nKQdieIs1NyZLWzbUQWTXeVfBEjZrwEI2ReSygeQ78hdmmFFZuHNMQ==
- Ironport-phdr: A9a23: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
Bonjour,
Nous avons ouvert une élection en mode "Codes de vote
générés sur la plateforme". Des électeurs n'ont pas reçu leur code de vote. Pouvez vous me confirmer que pour ce mode d'élection et dans belenios 1.9.1 il n'est pas possible de récupérer les code de vote sur le serveur comme cela est mentionné dans ce message :
Si vous parlez des « codes de vote » (demandés au début du vote, format
XXX-XXX-XXX-XXX-XXX), il n'est pas possible de les renvoyer, car le
serveur les oublie lors de l'ouverture de l'élection... mais vous avez
dû être invité à les télécharger lors de la préparation de l'élection.
Il vous suffit alors de consulter ce fichier et de renvoyer les codes
perdus vous-même.
Par avance merci pour la réponse.
Cordialement,
Anthony Perrin
- [belenios-discuss] récupération des code de vote, Anthony PERRIN, 29/09/2021
- Re: [belenios-discuss] récupération des code de vote, Anthony PERRIN, 29/09/2021
