- To: cado-nfs-discuss@lists.gforge.inria.fr
- Subject: [Cado-nfs-discuss] /usr/local/bin/sieve/las terminated unexpectedly
- Date: Mon, 19 Dec 2011 21:35:30 -0800
- List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss>
- List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
FreeBSD 9.0(RC2) amd64
# gcc --version
gcc (GCC) 4.2.1 20070831 patched [FreeBSD]
# g++ --version
g++ (GCC) 4.2.1 20070831 patched [FreeBSD]
# factor.sh 29660315107707419730868412471562256052529450176606958716148375177732039155423000975802956417478242327887011509464164441826551209047591 -t 4
/usr/local/bin/cadofactor.pl /tmp/cado.n9OaLQvhzf/param n=29660315107707419730868412471562256052529450176606958716148375177732039155423000975802956417478242327887011509464164441826551209047591 bindir=/usr/local/bin parallel=0 sieve_max_threads=4 poly_max_threads=4 nthchar=4 bwmt=2x2 wdir=/tmp/cado.n9OaLQvhzf sievenice=0 selectnice=0 logfile=/tmp/cado.n9OaLQvhzf/out
Info:--------------------------------------------------------------------------
Info:Initialization
Info:Reading the parameters...
Info:Initializing the working directory...
Info:Polynomial selection
Info:Total interval coverage: 0 %.
<snip>
Info:Starting job: 1980000000 2000000000
Info:Total interval coverage: 100 %.
Info:All done!
Info:The best polynomial is from `c134.kjout.580000000-600000000' (E = 3.02e-11).
Info:Generating factor base...
Info:Computing free relations...
Info:Sieve
Info:Checking previous files...
Info:Imported 8690 relations from `c134.freerels.gz'.
Info:Running total: 8690 relations.
Info:Starting job: 16000000 16020000
Error:Command `env nice -0 /usr/local/bin/sieve/las -I 13 -poly /tmp/cado.n9OaLQvhzf/c134.poly -fb /tmp/cado.n9OaLQvhzf/c134.roots -q0 16000000 -q1 16020000 -mt 4 -out /tmp/cado.n9OaLQvhzf/c134.rels.16000000-16020000.gz > /dev/null 2>&1' terminated unexpectedly with exit status 0.
FAILED ; data left in /tmp/cado.n9OaLQvhzf
I saved all the files in /tmp.
What may I do to help find the cause of this?
tomdean
- [Cado-nfs-discuss] /usr/local/bin/sieve/las terminated unexpectedly, Thomas D. Dean, 12/20/2011
- Re: [Cado-nfs-discuss] /usr/local/bin/sieve/las terminated unexpectedly, Zimmermann Paul, 12/21/2011
- Re: [Cado-nfs-discuss] /usr/local/bin/sieve/las terminated unexpectedly, Pierrick Gaudry, 12/21/2011
- <Possible follow-up(s)>
