- To: "Thomas D. Dean" <tomdean@speakeasy.org>
- Cc: cado-nfs-discuss@lists.gforge.inria.fr
- Subject: Re: [Cado-nfs-discuss] /usr/local/bin/sieve/las terminated unexpectedly
- Date: Wed, 21 Dec 2011 09:43:11 +0100
- List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss>
- List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
Hi Thomas,
> Date: Mon, 19 Dec 2011 19:01:41 -0800
> From: "Thomas D. Dean" <tomdean@speakeasy.org>
> FreeBSD 9.0(RC2)
> # gcc --version
> gcc (GCC) 4.2.1 20070831 patched [FreeBSD]
> # g++ --version
> g++ (GCC) 4.2.1 20070831 patched [FreeBSD]
> # factor.sh
> 29660315107707419730868412471562256052529450176606958716148375177732039155423000975802956417478242327887011509464164441826551209047591
> -t 4
> /usr/local/bin/cadofactor.pl /tmp/cado.n9OaLQvhzf/param
> n=29660315107707419730868412471562256052529450176606958716148375177732039155423000975802956417478242327887011509464164441826551209047591
> bindir=/usr/local/bin parallel=0 sieve_max_threads=4 poly_max_threads=4
> nthchar=4 bwmt=2x2 wdir=/tmp/cado.n9OaLQvhzf sievenice=0 selectnice=0
> logfile=/tmp/cado.n9OaLQvhzf/out
> Info:--------------------------------------------------------------------------
> Info:Initialization
> Info:Reading the parameters...
> Info:Initializing the working directory...
> Info:Polynomial selection
> Info:Total interval coverage: 0 %.
> <snip>
> Info:Starting job: 1980000000 2000000000
> Info:Total interval coverage: 100 %.
> Info:All done!
> Info:The best polynomial is from `c134.kjout.580000000-600000000' (E =
> 3.02e-11).
> Info:Generating factor base...
> Info:Computing free relations...
> Info:Sieve
> Info:Checking previous files...
> Info:Imported 8690 relations from `c134.freerels.gz'.
> Info:Running total: 8690 relations.
> Info:Starting job: 16000000 16020000
> Error:Command `env nice -0 /usr/local/bin/sieve/las -I 13 -poly
> /tmp/cado.n9OaLQvhzf/c134.poly -fb /tmp/cado.n9OaLQvhzf/c134.roots -q0
> 16000000 -q1 16020000 -mt 4 -out
> /tmp/cado.n9OaLQvhzf/c134.rels.16000000-16020000.gz > /dev/null 2>&1'
> terminated unexpectedly with exit status 0.
> FAILED ; data left in /tmp/cado.n9OaLQvhzf
> I saved all the files in /tmp.
> What may I do to help find the cause of this?
> tomdean
first please tell us which version of CADO-NFS you are using. Version 1.0,
1.1 or a development version (in which case give us the first line of git
log).
Then please send us the file
You might also send us the c134.poly file, so that we can check we get the
same
one.
Best regards,
Paul Zimmermann
- [Cado-nfs-discuss] /usr/local/bin/sieve/las terminated unexpectedly, Thomas D. Dean, 12/20/2011
- Re: [Cado-nfs-discuss] /usr/local/bin/sieve/las terminated unexpectedly, Zimmermann Paul, 12/21/2011
- Re: [Cado-nfs-discuss] /usr/local/bin/sieve/las terminated unexpectedly, Pierrick Gaudry, 12/21/2011
- <Possible follow-up(s)>
