- To: cado-nfs-discuss@lists.gforge.inria.fr
- Subject: [Cado-nfs-discuss] Factor Failed
- Date: Wed, 11 Jan 2012 23:02:08 -0800
- List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss>
- List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
I attempted to factor a 135-digit number. I previously factoried a
135-digit number, n. In attempting to factor n+1, I experienced an
error.
Factor.sh ran for 7 days, +- an hour, max. The last line of the log is
the output of 'time factor.sh...'
The command line was:
time factor.sh
296603151077074197308684124715622560525294501766069587161483751777320391554230009758029564174782423278870115094641644418265512090475911
-t 10
I saved the files in /tmp/cado*.
I have a complete log of the output of factor.sh. The
end of the log is:
Info:--------------------------------------------------------------------------
Info:Duplicate and singleton removal
Info:Removing duplicates...
Info:Starting job: 29400000 29600000
Info:Imported 334330 relations from `c135.rels.29400000-29600000.gz'.
Info:Running total: 25277282 relations.
Info:Number of relations left after duplicates: 21925642.
Info:Removing singletons...
Info:All done!
Info:Duplicates has already been done
Info:Purge has already been done
Info:Nrows: 9191243; Ncols: 9191083; Excess: 160.
Info:Merge
Info:Merging relations...
Info:Replaying merge history...
Info:Nrows: 2453580; Ncols: 2453420; Weight: 323951968.
Info:Linear algebra
Info:Calling Block-Wiedemann...
Error:Command `/usr/local/bin/linalg/bwc/bwc.pl :complete seed=1 thr=5x2
mpi=1x1 matrix=/tmp/cado.lR7LfORi6V/c135.small.bin nullspace=left
mm_impl=bucket interleaving=0 interval=1000 mn=64 splits=0,64 ys=0..64
wdir=/tmp/cado.lR7LfORi6V/c135.bwc shuffled_product=1
bwc_bindir=/usr/local/bin/linalg/bwc ' terminated unexpectedly with exit
status 1.
Error:STDOUT Running find /tmp/cado.lR7LfORi6V/c135.bwc -name
c135.small.5x2.????????.bin
Error:STDOUT # (a55366a) /usr/local/bin/linalg/bwc/dispatch
nullspace=left wdir=/tmp/cado.lR7LfORi6V/c135.bwc mm_impl=bucket thr=5x2
interval=1000 mpi=1x1 seed=1 mn=64 ys=0..64 interleaving=0
balancing=/tmp/cado.lR7LfORi6V/c135.bwc/c135.small.5x2.fb34e201.bin
sequential_cache_build=1 sanity_check_vector=H1
Error:STDOUT # Compiled with gcc 4.2.1 20070831 patched [FreeBSD]
Error:STDOUT # Compilation flags -std=c99 -g -W -Wall
Error:STDOUT 1 nodes on P
Error:STDOUT 9X79 .
Error:STDOUT . .
Error:STDOUT . .
Error:STDOUT . .
Error:STDOUT . .
Error:STDERR Writing balancing data to
Error:STDERR
Error:STDERR /usr/local/bin/linalg/bwc/dispatch nullspace=left
wdir=/tmp/cado.lR7LfORi6V/c135.bwc mm_impl=bucket thr=5x2 interval=1000
Error:STDERR # (a55366a) /usr/local/bin/linalg/bwc/dispatch
Error:STDERR # Compiled with gcc 4.2.1 20070831 patched [FreeBSD]
Error:STDERR # Compilation flags -std=c99 -g -W -Wall
Error:STDERR loading libmatmul_u64k1_bucket.so: /usr/lib/libstdc++.so.6:
version GLIBCXX_3.4.15 required by
/usr/local/lib/cado-nfs-1.1/libmatmul_u64k1_bucket.so not found
Error:STDERR /usr/local/bin/linalg/bwc/dispatch: died with signal 6, with
coredump
FAILED ; data left in /tmp/cado.lR7LfORi6V
3740108.003u 162825.943s 168:00:42.83 645.2% 294+2482k 213+337763io 63pf+0w
Does this indicate that libstdc++.so.6 is not the correct version? If
so, is this lib in building libgmp or cado? I used libgmp in other code
without problem...
Is there any way to restart the factoring from the saved retults,
assuming I can find and fix any problem?
My plan is to rebuild libgmp and cado-nfs-1.1 from the sources. The
version of gcc for FreeBSD 9.0, gcc 4.2.1, is patched for some kernel
reasons. I have gcc46, 4.6.3. Should I use this?
tomdean
- [Cado-nfs-discuss] Factor Failed, Thomas D. Dean, 01/12/2012
- Re: [Cado-nfs-discuss] Factor Failed, Zimmermann Paul, 01/12/2012
- Re: [Cado-nfs-discuss] Factor Failed, Thomas D. Dean, 01/12/2012
- Re: [Cado-nfs-discuss] Factor Failed, Emmanuel Thomé, 01/12/2012
