cado-nfs - Re: [Cado-nfs-discuss] Factor Failed
  • To: tomdean@speakeasy.org (Thomas D. Dean)
  • Cc: cado-nfs-discuss@lists.gforge.inria.fr
  • Subject: Re: [Cado-nfs-discuss] Factor Failed
  • Date: Thu, 12 Jan 2012 09:53:43 +0100
  • List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss>
  • List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
Tom,
> If I put LDFLAGS="..." in local.sh will this be picked up?
yes, this is the role of local.sh.
> Here is the big question.
> How do I restart the factoring process that ran for 7 days and failed
> with the error?
this should be easy.
1) first make a backup of /tmp/cado.lR7LfORi6V
2) then run:
cadofactor.pl n=296...911 wdir=/tmp/cado.lR7LfORi6V
param=/tmp/cado.lR7LfORi6V/c135.param -v
it should ask you whether you want to start the linear algebra again, then
answer "yes".
Note: for large factorization it is recommended to use the cadofactor.pl
script instead of factor.sh, since it is easier to restart a broken
factorization, by just restarting the script with the same arguments.
Paul Zimmermann
