- To: Shruti Rawal <vip.rs.shruti@gmail.com>
- Cc: "cado-nfs-discuss@lists.gforge.inria.fr" <cado-nfs-discuss@lists.gforge.inria.fr>
- Subject: Re: [Cado-nfs-discuss] How to run Block-Wiedemann in Cado-Nfs
- Date: Mon, 8 Apr 2013 11:28:14 +0200
- List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss>
- List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
Hi,
Be aware that bwc.pl is a fairly complicated piece of software.
There are a couple of ways to get you started.
- run a factorization example, and get the bwc.pl command line from
the .cmd file. This will give you a well-formed command line, but will
not give you an example of all possible configuration settings for
bwc, obviously.
- read linalg/bwc/README ; this file is not necessarily up to date,
but is surely better than nothing. It's the only place (beyond the
source itself, which is authoritative by definition) where you can get
information on some parameters which are not used in the scripts.
- use the linalg/bwc/bwc-trace.sh ; it's a shell script which is
meant as an illustration, and also a debug setup.
Once you have done that, you hopefully have better knowledge of
bwc.pl's command line, and can envision running it for larger
projects. It depends much on what you intend to do eventually, on
which size of systems, on which hardware, etc. The bwc binaries offer
a great amount of flexibility, but wielding their full power is out of
reach for the bwc.pl script, at least for the moment.
Best,
E.
On Mon, Apr 8, 2013 at 9:37 AM, Shruti Rawal <vip.rs.shruti@gmail.com> wrote:
> Helo,
> Can I please be helped on how I can run just the block-wiedemann part of the
> Cado-nfs.
> Kindly help with some example to run it through bwc.pl with some parameters,
> if it can be used to run block wiedemann.
> Hoping to get a n early reply.
> Thanks and Regards,
> Shruti Rawal
> India
> _______________________________________________
> Cado-nfs-discuss mailing list
> Cado-nfs-discuss@lists.gforge.inria.fr
> http://lists.gforge.inria.fr/cgi-bin/mailman/listinfo/cado-nfs-discuss
- [Cado-nfs-discuss] How to run Block-Wiedemann in Cado-Nfs, Shruti Rawal, 04/08/2013
- Re: [Cado-nfs-discuss] How to run Block-Wiedemann in Cado-Nfs, Emmanuel Thomé, 04/08/2013
