cado-nfs - Re: [Cado-nfs-discuss] Possible problem with "purge!'s ARGV?
  • To: Zimmermann Paul <Paul.Zimmermann@inria.fr>
  • Cc: cado-nfs-discuss@lists.gforge.inria.fr
  • Subject: Re: [Cado-nfs-discuss] Possible problem with "purge!'s ARGV?
  • Date: Mon, 08 Apr 2013 10:01:30 +0100
  • List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss>
  • List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
That's good.
My plan was to write a Perl function along these lines:
sub sanity_clause($$$$)
my ($host, $bindir, $tmpdir, $wdir) = @_;
my @binaries = ('sieve/las',
'sqrt/sqrt',
# Etc
if ($host eq 'localhost') {
-d $bindir && -r $bindir && -x $bindir or die "$bindir is
inaccesible\n"
foreach (@binaries) {
-x "$bindir/$_ or die "$bindir/$_ is not executable\n";
# Test $tmpdir and "wdir for read/writable directories or die.
} else {
# Use ssh to perform analogous tests on the remote hosts
# but warn rather than die.
#Set a flag in an array @accessible_hosts if all tests pass
# and then use that to decide whether to run jobs there.
and , of course, to call sanity_clause() for each of the machines which
have at least one core set in mach_desc. Even after all that has been
done, explicit permission should be needed for deletion of relations to
take place.
Paul
On Sun, 2013-04-07 at 22:20 +0200, Zimmermann Paul wrote:
> Paul,
> > I tried to add another machine as a siever but didn't really understand
> > the format of the mach_desc file and, in particular, the scope of the
> > bindir declaration. When cadofactor.pl restarted it tried to de-dup and
> > purge the relations found so far but used the wrong path. Instead of
> > dying with an error "program not found" or similar, it deleted all the
> > relation files.
> we are aware of that bug:
> https://gforge.inria.fr/tracker/index.php?func=detail&aid=13209&group_id=2065&atid=7442
> It should be fixed in the new version of the cadofactor script that Alex is
> currently designing.
> The idea is that relations should not be deleted without an explicit
> "YES" from the user.
> Paul
