- From: Christophe Clavier <christophe.clavier@unilim.fr>
- To: Cado-nfs-discuss@lists.gforge.inria.fr
- Subject: [Cado-nfs-discuss] CADO-NFS 2.0: Small issue with factor.sh
- Date: Sat, 23 Nov 2013 18:05:59 +0100
- List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss>
- List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
Hello,
I wonder whether I have found a small bug in the factor.sh script of CADO-NFS 2.0.
Line 287 reads as:
$host cores=$cores
but the variable host is not defined.
I locally fixed the problem by modifying this line as:
$host cores=$cores
which writes "localhost cores=xxx" (instead of " cores=xxx") in the machine description file, but I am not sure this is the correct way to fix the problem.
Regards
Christophe
- [Cado-nfs-discuss] CADO-NFS 2.0: Small issue with factor.sh, Christophe Clavier, 11/23/2013
- Re: [Cado-nfs-discuss] CADO-NFS 2.0: Small issue with factor.sh, Christophe Clavier, 11/24/2013
- Re: [Cado-nfs-discuss] CADO-NFS 2.0: Small issue with factor.sh, Alexander Kruppa, 11/25/2013
