cado-nfs - Re: [Cado-nfs-discuss] CADO-NFS 2.0: Small issue with factor.sh
  • To: Christophe Clavier <christophe.clavier@unilim.fr>
  • Cc: Cado-nfs-discuss@lists.gforge.inria.fr
  • Subject: Re: [Cado-nfs-discuss] CADO-NFS 2.0: Small issue with factor.sh
  • Date: Mon, 25 Nov 2013 11:42:07 +0100 (CET)
  • List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss>
  • List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
----- Original Message -----
> From: "Christophe Clavier" <christophe.clavier@unilim.fr>
> To: Cado-nfs-discuss@lists.gforge.inria.fr
> Sent: Sunday, 24 November, 2013 2:27:00 AM
> Sorry, I meant that the fix was :
> $hostnames cores=$cores
> Regards
> Christophe
Hi Christophe,
thanks for the report! This is indeed a bug, introduced in commit d3d6a82c. I
added this fix:
if [ -z "$CADO_USEHOST" ] && echo "$hostnames" | grep -E "^(localhost,
*)*localhost$" > /dev/null
then
- server_address="server.address=localhost"
+ host=localhost # For the Perl script
+ server_address="server.address=localhost" # For the Python script
else
+ host=`hostname --short`
server_address=""
fi
Note that the $hostnames variable is really meant for the Python script,
i.e., it is set by the -h parameter. It defaults to localhost, so without an
-h parameter (which should not be used with -pl), it'll happen to work, but
CADO_USEHOST would not be taken into account.
Alex
> Le 23/11/2013 18:05, Christophe Clavier a écrit :
> > Hello,
> > I wonder whether I have found a small bug in the factor.sh script
> > of
> > CADO-NFS 2.0.
> > Line 287 reads as:
> > $host cores=$cores
> > but the variable host is not defined.
> > I locally fixed the problem by modifying this line as:
> > $host cores=$cores
> > which writes "localhost cores=xxx" (instead of " cores=xxx") in
> > the
> > machine description file, but I am not sure this is the correct way
> > to
> > fix the problem.
> > Regards
> > Christophe
> > _______________________________________________
> > Cado-nfs-discuss mailing list
> > http://lists.gforge.inria.fr/cgi-bin/mailman/listinfo/cado-nfs-discuss
