- To: cado-nfs-discuss@lists.gforge.inria.fr
- Subject: [Cado-nfs-discuss] Cado NFS 2.0 alpha
- Date: Tue, 26 Nov 2013 17:10:51 +0800
- List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss>
- List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
Hi, I'm failing to "make" the file on my windows computer running cygwin. I did not "configure" as advised by "README", and entered `make GMP=/home/TYanBo/gamp-5.1.3` after untar and moving into the directory. The error message displayed was:
-- MPI is not enabled
-- Using libs: (math) (pthreads)
-- Configuring done
CMake Error at misc/CMakeList.txt:5 (add_executable):
Cannot find source file:
convert_rels.c
Tried extensions .c .C .c++ .cc .cpp .cxx .m .M .mm .h .hh .h++ .hm .hpp
.hxx .in .txx
-- Build files have been written to:/home/TYanBo/cado-nfs-2.0alpha_555e97b6a/build/174-581
make: *** No rule to make target 'all". Stop.
Makefile:5: recipe for target 'all' failed
make: *** [all] Error 2
Any help would be appreciated. Thanks everybody!
Regards,
Bo
- [Cado-nfs-discuss] Cado NFS 2.0 alpha, Yan Bo Ti, 11/26/2013
- <Possible follow-up(s)>
- Re: [Cado-nfs-discuss] Cado NFS 2.0 alpha, Zimmermann Paul, 11/26/2013
