cado-nfs - [Cado-nfs-discuss] Crash in freshly built 2.0 on Gentoo amd64
  • To: cado-nfs-discuss@lists.gforge.inria.fr
  • Subject: [Cado-nfs-discuss] Crash in freshly built 2.0 on Gentoo amd64
  • Date: Fri, 14 Feb 2014 10:18:47 +0000
  • List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss>
  • List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
A few days ago I had to rebuild my AMD-64 system with the latest Gentoo.
A fresh copy of cado-nfs-2.0.tar.gz was subsequently unpacked correctly.
"make" ran without complaint. Running
./factor.sh 90377629292003121684002147101760858109247336549001090677693 -t 2
ran the poly finding and sieving stages without issue. The filtering
stage then crashed with the full log as given below. If desired I can
package up /tmp/cado.VgIbqQcYNM and make it available. It is 17M
uncompressed and far too big for this email.
Strangely enough the same procedure worked perfectly on another Gentoo
amd64 system just after the initial release of CADO-NFS V2.0.
Any suggestions as to how I should proceed?
Thanks,
Paul
8<----------------------------------------------------------->8
pcl@anubis ~/nums/cado-nfs-2.0 $ ./factor.sh
Info:root: Command line parameters:
/home/pcl/nums/cado-nfs-2.0/scripts/cadofactor/cadofactor.py
/tmp/cado.VgIbqQcYNM/param
'N=90377629292003121684002147101760858109247336549001090677693'
'tasks.execpath=/home/pcl/nums/cado-nfs-2.0/build/anubis' 'tasks.threads=2'
'tasks.workdir=/tmp/cado.VgIbqQcYNM' 'slaves.hostnames=localhost'
'slaves.nrclients=1'
'slaves.scriptpath=/home/pcl/nums/cado-nfs-2.0/scripts/cadofactor'
'server.address=localhost' 'slaves.basepath=/tmp/cado.VgIbqQcYNM/client/'
Info:HTTP server: Using non-threaded HTTPS server
Info:HTTP server: Using whitelist: localhost
Info:Complete Factorization: Factoring
Info:HTTP server: serving at https://localhost:8001 (127.0.0.1)
Info:HTTP server: You can start additional wuclient2.py scripts with
parameters: --server=https://localhost:8001
--certsha1=87cd09b5280b9749d6d8bd07a59d7da2aff04c39
Info:HTTP server: If you want to start additional clients, remember to add
their hosts to server.whitelist
Info:Client Launcher: Starting client id localhost on host localhost
Info:Client Launcher: Running clients: localhost (Host localhost, PID 30362)
Info:Polynomial Selection: Starting
Info:Polynomial Selection: No polynomial was previously found
Info:Polynomial Selection: Adding workunit c59_polyselect_0-5000 to database
Info:Polynomial Selection: Adding workunit c59_polyselect_5000-10000 to
database
Info:HTTP server: 127.0.0.1 Sending workunit c59_polyselect_0-5000 to client
localhost
Info:HTTP server: 127.0.0.1 Sending workunit c59_polyselect_5000-10000 to
client localhost
Info:Polynomial Selection: New best polynomial from file
/tmp/cado.VgIbqQcYNM/c59.upload/c59.polyselect.b63v55.0-5000: Murphy E =
2.72e-06
Info:Polynomial Selection: Marking workunit c59_polyselect_0-5000 as ok
Info:Polynomial Selection: Best polynomial from file
/tmp/cado.VgIbqQcYNM/c59.upload/c59.polyselect.7ishyt.5000-10000 with
E=2.4e-06 is no better than current best with E=2.72e-06
Info:Polynomial Selection: Marking workunit c59_polyselect_5000-10000 as ok
Info:Polynomial Selection: Finished, best polynomial from file
/tmp/cado.VgIbqQcYNM/c59.upload/c59.polyselect.b63v55.0-5000 has Murphy_E =
2.72e-06
Info:Generate Factor Base: Starting
Info:Generate Factor Base: Finished
Info:Generate Free Relations: Starting
Info:Generate Free Relations: Found 12323 free relations
Info:Generate Free Relations: Finished
Info:Lattice Sieving: Starting
Info:Lattice Sieving: Adding workunit c59_sieving_200000-201000 to database
Info:Lattice Sieving: Adding workunit c59_sieving_201000-202000 to database
Info:Lattice Sieving: Adding workunit c59_sieving_202000-203000 to database
Info:Lattice Sieving: Adding workunit c59_sieving_203000-204000 to database
Info:Lattice Sieving: Adding workunit c59_sieving_204000-205000 to database
Info:Lattice Sieving: Adding workunit c59_sieving_205000-206000 to database
Info:Lattice Sieving: Adding workunit c59_sieving_206000-207000 to database
Info:Lattice Sieving: Adding workunit c59_sieving_207000-208000 to database
Info:Lattice Sieving: Adding workunit c59_sieving_208000-209000 to database
Info:Lattice Sieving: Adding workunit c59_sieving_209000-210000 to database
Info:HTTP server: 127.0.0.1 Sending workunit c59_sieving_200000-201000 to
client localhost
Info:Lattice Sieving: Adding workunit c59_sieving_210000-211000 to database
Info:HTTP server: 127.0.0.1 Sending workunit c59_sieving_201000-202000 to
client localhost
Info:Lattice Sieving: Adding workunit c59_sieving_211000-212000 to database
Info:Lattice Sieving: Found 13630 relations in
'/tmp/cado.VgIbqQcYNM/c59.upload/c59.sieving.200000-201000.1uwvzv.gz', total
is now 13630/222540
Info:Lattice Sieving: Marking workunit c59_sieving_200000-201000 as ok
Info:HTTP server: 127.0.0.1 Sending workunit c59_sieving_202000-203000 to
client localhost
Info:Lattice Sieving: Adding workunit c59_sieving_212000-213000 to database
Info:Lattice Sieving: Found 15527 relations in
'/tmp/cado.VgIbqQcYNM/c59.upload/c59.sieving.201000-202000.7nlz09.gz', total
is now 29157/222540
Info:Lattice Sieving: Marking workunit c59_sieving_201000-202000 as ok
Info:HTTP server: 127.0.0.1 Sending workunit c59_sieving_203000-204000 to
client localhost
Info:Lattice Sieving: Adding workunit c59_sieving_213000-214000 to database
Info:Lattice Sieving: Found 12978 relations in
'/tmp/cado.VgIbqQcYNM/c59.upload/c59.sieving.202000-203000.385eg_.gz', total
is now 42135/222540
Info:Lattice Sieving: Marking workunit c59_sieving_202000-203000 as ok
Info:HTTP server: 127.0.0.1 Sending workunit c59_sieving_204000-205000 to
client localhost
Info:Lattice Sieving: Adding workunit c59_sieving_214000-215000 to database
Info:Lattice Sieving: Found 11879 relations in
'/tmp/cado.VgIbqQcYNM/c59.upload/c59.sieving.203000-204000.p5pstd.gz', total
is now 54014/222540
Info:Lattice Sieving: Marking workunit c59_sieving_203000-204000 as ok
Info:HTTP server: 127.0.0.1 Sending workunit c59_sieving_205000-206000 to
client localhost
Info:Lattice Sieving: Adding workunit c59_sieving_215000-216000 to database
Info:Lattice Sieving: Found 14441 relations in
'/tmp/cado.VgIbqQcYNM/c59.upload/c59.sieving.204000-205000.fouvpw.gz', total
is now 68455/222540
Info:Lattice Sieving: Marking workunit c59_sieving_204000-205000 as ok
Info:HTTP server: 127.0.0.1 Sending workunit c59_sieving_206000-207000 to
client localhost
Info:Lattice Sieving: Adding workunit c59_sieving_216000-217000 to database
Info:Lattice Sieving: Found 15539 relations in
'/tmp/cado.VgIbqQcYNM/c59.upload/c59.sieving.205000-206000.8uuex1.gz', total
is now 83994/222540
Info:Lattice Sieving: Marking workunit c59_sieving_205000-206000 as ok
Info:HTTP server: 127.0.0.1 Sending workunit c59_sieving_207000-208000 to
client localhost
Info:Lattice Sieving: Adding workunit c59_sieving_217000-218000 to database
Info:Lattice Sieving: Found 13746 relations in
'/tmp/cado.VgIbqQcYNM/c59.upload/c59.sieving.206000-207000.2t3chr.gz', total
is now 97740/222540
Info:Lattice Sieving: Marking workunit c59_sieving_206000-207000 as ok
Info:HTTP server: 127.0.0.1 Sending workunit c59_sieving_208000-209000 to
client localhost
Info:Lattice Sieving: Adding workunit c59_sieving_218000-219000 to database
Info:Lattice Sieving: Found 16287 relations in
'/tmp/cado.VgIbqQcYNM/c59.upload/c59.sieving.207000-208000.9afj9j.gz', total
is now 114027/222540
Info:Lattice Sieving: Marking workunit c59_sieving_207000-208000 as ok
Info:HTTP server: 127.0.0.1 Sending workunit c59_sieving_209000-210000 to
client localhost
Info:Lattice Sieving: Adding workunit c59_sieving_219000-220000 to database
Info:Lattice Sieving: Found 13004 relations in
'/tmp/cado.VgIbqQcYNM/c59.upload/c59.sieving.208000-209000.ic1qxd.gz', total
is now 127031/222540
Info:Lattice Sieving: Marking workunit c59_sieving_208000-209000 as ok
Info:HTTP server: 127.0.0.1 Sending workunit c59_sieving_210000-211000 to
client localhost
Info:Lattice Sieving: Adding workunit c59_sieving_220000-221000 to database
Info:Lattice Sieving: Found 14759 relations in
'/tmp/cado.VgIbqQcYNM/c59.upload/c59.sieving.209000-210000.bklz4_.gz', total
is now 141790/222540
Info:Lattice Sieving: Marking workunit c59_sieving_209000-210000 as ok
Info:HTTP server: 127.0.0.1 Sending workunit c59_sieving_211000-212000 to
client localhost
Info:Lattice Sieving: Adding workunit c59_sieving_221000-222000 to database
Info:Lattice Sieving: Found 13772 relations in
'/tmp/cado.VgIbqQcYNM/c59.upload/c59.sieving.210000-211000.f18w1x.gz', total
is now 155562/222540
Info:Lattice Sieving: Marking workunit c59_sieving_210000-211000 as ok
Info:HTTP server: 127.0.0.1 Sending workunit c59_sieving_212000-213000 to
client localhost
Info:Lattice Sieving: Adding workunit c59_sieving_222000-223000 to database
Info:Lattice Sieving: Found 15626 relations in
'/tmp/cado.VgIbqQcYNM/c59.upload/c59.sieving.211000-212000.myffn2.gz', total
is now 171188/222540
Info:Lattice Sieving: Marking workunit c59_sieving_211000-212000 as ok
Info:HTTP server: 127.0.0.1 Sending workunit c59_sieving_213000-214000 to
client localhost
Info:Lattice Sieving: Adding workunit c59_sieving_223000-224000 to database
Info:Lattice Sieving: Found 10293 relations in
'/tmp/cado.VgIbqQcYNM/c59.upload/c59.sieving.212000-213000.o69i0k.gz', total
is now 181481/222540
Info:Lattice Sieving: Marking workunit c59_sieving_212000-213000 as ok
Info:HTTP server: 127.0.0.1 Sending workunit c59_sieving_214000-215000 to
client localhost
Info:Lattice Sieving: Adding workunit c59_sieving_224000-225000 to database
Info:Lattice Sieving: Found 12287 relations in
'/tmp/cado.VgIbqQcYNM/c59.upload/c59.sieving.213000-214000.y739lt.gz', total
is now 193768/222540
Info:Lattice Sieving: Marking workunit c59_sieving_213000-214000 as ok
Info:HTTP server: 127.0.0.1 Sending workunit c59_sieving_215000-216000 to
client localhost
Info:Lattice Sieving: Adding workunit c59_sieving_225000-226000 to database
Info:Lattice Sieving: Found 16368 relations in
'/tmp/cado.VgIbqQcYNM/c59.upload/c59.sieving.214000-215000.73m4kz.gz', total
is now 210136/222540
Info:Lattice Sieving: Marking workunit c59_sieving_214000-215000 as ok
Info:HTTP server: 127.0.0.1 Sending workunit c59_sieving_216000-217000 to
client localhost
Info:Lattice Sieving: Adding workunit c59_sieving_226000-227000 to database
Info:Lattice Sieving: Found 13180 relations in
'/tmp/cado.VgIbqQcYNM/c59.upload/c59.sieving.215000-216000.cqaodj.gz', total
is now 223316/222540
Info:Lattice Sieving: Marking workunit c59_sieving_215000-216000 as ok
Info:HTTP server: 127.0.0.1 Sending workunit c59_sieving_217000-218000 to
client localhost
Info:Lattice Sieving: Adding workunit c59_sieving_227000-228000 to database
Info:Lattice Sieving: Reached target of 222540 relations, now have 223316
Info:Filtering - Duplicate Removal, splitting pass: Starting
Info:Filtering - Duplicate Removal, splitting pass: Splitting 16 new files
Warning:Command: Process with PID 3744 finished with return code -6
Traceback (most recent call last):
File "/home/pcl/nums/cado-nfs-2.0/scripts/cadofactor/cadofactor.py", line
75, in <module>
factors = factorjob.run()
File "/home/pcl/nums/cado-nfs-2.0/scripts/cadofactor/cadotask.py", line
3277, in run
while self.run_next_task():
3337, in run_next_task
return task.run()
1919, in run
raise Exception("Program failed")
Exception: Program failed
FAILED ; data left in /tmp/cado.VgIbqQcYNM
