- To: Cyril Bouvier <Cyril.Bouvier@loria.fr>
- Cc: cado-nfs-discuss@lists.gforge.inria.fr
- Subject: Re: [Cado-nfs-discuss] Crash in freshly built 2.0 on Gentoo amd64
- Date: Fri, 14 Feb 2014 10:46:12 +0000
- List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss>
- List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
On Fri, 2014-02-14 at 11:23 +0100, Cyril Bouvier wrote:
> Hi,
> The whole cado directory won't be necessary but can you send us all the
> files beginning with c59.duplicates* and c59.purge.purge.* (if any).
Given that hint, I found this output fascinating:
pcl@anubis /tmp/cado.VgIbqQcYNM/c59.upload $ file *
c59.polyselect.7ishyt.5000-10000: ASCII text
c59.polyselect.b63v55.0-5000: ASCII text
c59.sieving.200000-201000.1uwvzv.gz: gzip compressed data, from
VM/CMS
c59_sieving_200000-201000.e4pin1.stderr0: ASCII text
c59.sieving.201000-202000.7nlz09.gz: gzip compressed data, from
Unix, last modified: Fri Feb 14 10:04:16 2014, max speed
c59_sieving_201000-202000.n9bgap.stderr0: ASCII text
c59.sieving.202000-203000.385eg_.gz: gzip compressed data, from
Unix, last modified: Fri Feb 14 10:04:21 2014, max speed
c59_sieving_202000-203000.qamj19.stderr0: ASCII text
and so on. All subsequent *.gz are from Unix.
The data from VM/CMS is curious to say the least.
Paul
- [Cado-nfs-discuss] Crash in freshly built 2.0 on Gentoo amd64, Paul Leyland, 02/14/2014
- Re: [Cado-nfs-discuss] Crash in freshly built 2.0 on Gentoo amd64, Cyril Bouvier, 02/14/2014
- Re: [Cado-nfs-discuss] Crash in freshly built 2.0 on Gentoo amd64, Paul Leyland, 02/14/2014
- Re: [Cado-nfs-discuss] Crash in freshly built 2.0 on Gentoo amd64, Alexander Kruppa, 02/14/2014
