- From: Christophe Clavier <christophe.clavier@unilim.fr>
- To: cado-nfs-discuss@lists.gforge.inria.fr
- Subject: [Cado-nfs-discuss] Unfinished factorization
- Date: Mon, 10 Mar 2014 15:48:32 +0100
- List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss>
- List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
Hello,
I have some problem to terminate the factorization of a c155 with cado 2.0.
All seemed correct up to the square root phase which terminates with error.
Here is a log of the standard output :
Info:Polynomial Selection: Starting
Info:Polynomial Selection: Best polynomial previously found in /home/clavip01/math/cado-nfs-2.0/servers/A_9120_0988.c155/tmp/A_9120_0988.c155.upload/A_9120_0988.c155.polyselect.9448w_.1000000-1200000 has Murphy_E = 2.4e-12
Info:Polynomial Selection: Polynomial selection already finished - nothing to do
Info:Lattice Sieving: Starting
Info:Lattice Sieving: Reached target of 70000000 relations, now have 107044798
Info:Filtering - Duplicate Removal, splitting pass: Starting
Info:Filtering - Duplicate Removal, splitting pass: No new files to split
Info:Filtering - Duplicate Removal, splitting pass: Relations per slice: 0: 53523685, 1: 53521113
Info:Filtering - Duplicate Removal, removal pass: Starting
Info:Filtering - Duplicate Removal, removal pass: No new files for slice 0, nothing to do
Info:Filtering - Duplicate Removal, removal pass: No new files for slice 1, nothing to do
Info:Filtering - Duplicate Removal, removal pass: 84362931 unique relations remain in total
Info:Filtering - Singleton removal: Starting
Info:Filtering - Singleton removal: Already have a purged file, and no new input relations available. Nothing to do
Info:Lattice Sieving: Cancelling remaining workunits
Info:Square Root: Starting
Info:Square Root: Creating file of (a,b) values
Info:Square Root: Trying dependency 0
Warning:Command: Process with PID 15120 finished with return code 1
Traceback (most recent call last):
File "../../scripts/cadofactor/cadofactor.py", line 75, in <module>
factors = factorjob.run()
File "/home/clavip01/math/cado-nfs-2.0/scripts/cadofactor/cadotask.py", line 3277, in run
while self.run_next_task():
File "/home/clavip01/math/cado-nfs-2.0/scripts/cadofactor/cadotask.py", line 3337, in run_next_task
return task.run()
File "/home/clavip01/math/cado-nfs-2.0/scripts/cadofactor/cadotask.py", line 2694, in run
raise Exception("Program failed")
Exception: Program failed
Any help appreciated
Christophe
- [Cado-nfs-discuss] Unfinished factorization, Christophe Clavier, 03/10/2014
- Re: [Cado-nfs-discuss] Unfinished factorization, Alexander Kruppa, 03/10/2014
- Re: [Cado-nfs-discuss] Unfinished factorization, Zimmermann Paul, 03/10/2014
- Re: [Cado-nfs-discuss] Unfinished factorization, Christophe Clavier, 03/10/2014
