- From: Christophe Clavier <christophe.clavier@unilim.fr>
- To: Zimmermann Paul <Paul.Zimmermann@inria.fr>
- Cc: cado-nfs-discuss@lists.gforge.inria.fr
- Subject: Re: [Cado-nfs-discuss] Unfinished factorization
- Date: Mon, 10 Mar 2014 17:46:49 +0100
- List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss>
- List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
As analysed by Paul (in private mails) this was a stupid problem of disk full.
The problem is now solved, and factors have been found.
Many thanks Paul.
Christophe
Le 10/03/2014 16:13, Zimmermann Paul a écrit :
Dear Christophe,
Date: Mon, 10 Mar 2014 15:48:32 +0100we have improved the user feedback in case of error in the git version.
Hello,
I have some problem to terminate the factorization of a c155 with cado 2.0.
All seemed correct up to the square root phase which terminates with error.
Here is a log of the standard output :
Info:Square Root: Trying dependency 0
Warning:Command: Process with PID 15120 finished with return code 1
There should be in
/home/clavip01/math/cado-nfs-2.0/servers/A_9120_0988.c155/tmp some files
A_9120_0988.c155*sqrt*, please could you send them?
Paul
- [Cado-nfs-discuss] Unfinished factorization, Christophe Clavier, 03/10/2014
- Re: [Cado-nfs-discuss] Unfinished factorization, Alexander Kruppa, 03/10/2014
- Re: [Cado-nfs-discuss] Unfinished factorization, Zimmermann Paul, 03/10/2014
- Re: [Cado-nfs-discuss] Unfinished factorization, Christophe Clavier, 03/10/2014
