- To: meng <qsmeng@126.com>
- Cc: cado-nfs-discuss@lists.gforge.inria.fr
- Subject: Re: [Cado-nfs-discuss] about the choice on parameter on degree 6
- Date: Fri, 28 Mar 2014 15:27:26 +0100
- List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss>
- List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
Dear Meng,
> Date: Fri, 28 Mar 2014 22:23:03 +0800 (CST)
> From: meng <qsmeng@126.com>
> Hello,
> cado-nfs has a directory containing parameters used for the whole
> factoring on the degree 5 case, but no parameters are recommended on the
> degree 6 case. Does anyone has any idea on the the choice of these
> parameters, especially on parameters for polynomial selection on the degree
> 6, like the theory or some heuristic parameters?
> Thank you.
> best regards,
> Qingshu Meng
did you look at params.c220 in the git version?
Paul
- [Cado-nfs-discuss] about the choice on parameter on degree 6, meng, 03/28/2014
- Re: [Cado-nfs-discuss] about the choice on parameter on degree 6, Zimmermann Paul, 03/28/2014
- Re: [Cado-nfs-discuss] about the choice on parameter on degree 6, meng, 03/29/2014
- Re: [Cado-nfs-discuss] about the choice on parameter on degree 6, Zimmermann Paul, 03/29/2014
