cado-nfs - Re: [Cado-nfs-discuss] about the choice on parameter on degree 6
  • To: meng <qsmeng@126.com>
  • Cc: cado-nfs-discuss@lists.gforge.inria.fr
  • Subject: Re: [Cado-nfs-discuss] about the choice on parameter on degree 6
  • Date: Sat, 29 Mar 2014 08:49:33 +0100
  • List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss>
  • List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
Dear Meng,
> Date: Sat, 29 Mar 2014 08:46:39 +0800 (CST)
> From: meng <qsmeng@126.com>
> Dear Paul,
> Thank you for your email. I just now read the params.c220.
> In recent version some partial parameters on polynomial are: degree , P
> , nq. In versions before March,2013 there is another parameter lq, which
> disappeared in later version. Different polynomials will be generated for
> different set of parameters. So the number of polynomials is very big. Is
> there some general consideration on the choice of these parameters?
> I expect some discuss on this problem in this mail list.
> Thank you.
> Best regards,
> Qingshu Meng
lq was the number of small primes q used in Kleinjung's 2008 polynomial
selection algorithm : for each leading coefficient a_d, we tried values of
\ell = p_1 p_2 q_1 q_2 ... q_{lq} with P < p1, p2 < 2P.
Now we only use the parameter nq, which is the number of values of
q_1 q_2 ... q_{lq} (together with corresponding roots) tried for each
p_1 p_2 product.
Since for degree d there can be up to d roots for each q_j, there might be
up to d^{lq} roots for each q_1 q_2 ... q_{lq} term, thus in most cases we
try only one q_1 q_2 ... q_{lq} product. For example with degree 5 and
nq=625 we can take lq=4.
I hope this clarifies things. Feel free to propose improvements.
Paul
