cado-nfs - [Cado-nfs-discuss] Cmake does not respect path to gcc
  • To: cado-nfs-discuss@lists.gforge.inria.fr
  • Subject: [Cado-nfs-discuss] Cmake does not respect path to gcc
  • Date: Wed, 23 Jul 2014 18:47:01 +0200
  • List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss/>
  • List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
Hello,
trying to install cado-nfs with the guix userland package manager:
https://www.gnu.org/software/guix/
on top of a debian distribution, I hit the following bug.
Gcc-4.8.2 is installed in a non-standard location, referenced in $PATH:
$ which gcc
/home/privat/.guix-profile/bin/gcc
But the cmake check for gcc uses the debian one it finds in /usr/bin
(and fails, potentially because it ends up mixing the guix and the
debian linker):
-- The C compiler identification is GNU 4.7.2
-- The CXX compiler identification is GNU 4.7.2
-- Check for working C compiler: /usr/bin/cc
-- Check for working C compiler: /usr/bin/cc -- broken
CMake Error at
/gnu/store/w0pmvn1wcn1zj175fv2ima4bxlbw5cx1-cmake-2.8.12/share/cmake-2.8/Modules/CMakeTestCCompiler.cmake:61
(message):
The C compiler "/usr/bin/cc" is not able to compile a simple test program.
To me this looks like a bug in cmake itself, or did I make a mistake?
Or could you change your configuration so as to take $PATH into account?
I also tried
CC=`which gcc` make
without success.
Andreas
