- To: "cado-nfs-discuss@lists.gforge.inria.fr" <cado-nfs-discuss@lists.gforge.inria.fr>
- Subject: Re: [Cado-nfs-discuss] Cmake does not respect path to gcc
- Date: Wed, 23 Jul 2014 18:52:51 +0200
- List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss/>
- List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
Not obeying the user PATH is at the very least a misfeature, and I
personally would be inclined to naming it a quite severe bug.
We could change this behaviour, and this may be discussed.
On the other hand, it's entirely possible to constrain a particular CC. Just
do:
CC=`which gcc` CXX=`which g++` make
or use local.sh to set these. If you prefer to use pure cmake, then
you'd have to change CMAKE_C_COMPILER and CMAKE_CXX_COMPILER with
ccmake.
E.
On Wed, Jul 23, 2014 at 6:47 PM, Andreas Enge <andreas.enge@inria.fr> wrote:
> Hello,
> trying to install cado-nfs with the guix userland package manager:
> https://www.gnu.org/software/guix/
> on top of a debian distribution, I hit the following bug.
> Gcc-4.8.2 is installed in a non-standard location, referenced in $PATH:
> $ which gcc
> /home/privat/.guix-profile/bin/gcc
> But the cmake check for gcc uses the debian one it finds in /usr/bin
> (and fails, potentially because it ends up mixing the guix and the
> debian linker):
> -- The C compiler identification is GNU 4.7.2
> -- The CXX compiler identification is GNU 4.7.2
> -- Check for working C compiler: /usr/bin/cc
> -- Check for working C compiler: /usr/bin/cc -- broken
> CMake Error at
> /gnu/store/w0pmvn1wcn1zj175fv2ima4bxlbw5cx1-cmake-2.8.12/share/cmake-2.8/Modules/CMakeTestCCompiler.cmake:61
> (message):
> The C compiler "/usr/bin/cc" is not able to compile a simple test program.
> To me this looks like a bug in cmake itself, or did I make a mistake?
> Or could you change your configuration so as to take $PATH into account?
> I also tried
> CC=`which gcc` make
> without success.
> Andreas
> _______________________________________________
> Cado-nfs-discuss mailing list
> Cado-nfs-discuss@lists.gforge.inria.fr
> http://lists.gforge.inria.fr/cgi-bin/mailman/listinfo/cado-nfs-discuss
- [Cado-nfs-discuss] Cmake does not respect path to gcc, Andreas Enge, 07/23/2014
- Re: [Cado-nfs-discuss] Cmake does not respect path to gcc, Emmanuel Thomé, 07/23/2014
- Re: [Cado-nfs-discuss] Cmake does not respect path to gcc, Andreas Enge, 07/24/2014
- Re: [Cado-nfs-discuss] Cmake does not respect path to gcc, Zimmermann Paul, 07/25/2014
- Re: [Cado-nfs-discuss] Cmake does not respect path to gcc, Emmanuel Thomé, 07/28/2014
