- From: Christophe Clavier <christophe.clavier@unilim.fr>
- To: cado-nfs-discuss@lists.gforge.inria.fr
- Subject: [Cado-nfs-discuss] Problem on the merge phase
- Date: Thu, 11 Dec 2014 08:49:18 +0100
- List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss/>
- List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
Hello, I have a problem on the merge phase of a factorization with cado 2.1.1. Hereunder is reported the end of the log. I have started again the factorization by importing the poly file and the relations but no more success. I have checked the relations with check_rels and they seem ok. Can anyone help me terminate this factorization? Thanks Christophe Info:Filtering - Duplicate Removal, splitting pass: Starting Info:Filtering - Duplicate Removal, splitting pass: Splitting 1506 new files Info:Filtering - Duplicate Removal, splitting pass: Relations per slice: 0: 10027687, 1: 10029492 Info:Filtering - Duplicate Removal, removal pass: Starting Info:Filtering - Duplicate Removal, removal pass: 9258624 unique relations remain on slice 0 Info:Filtering - Duplicate Removal, removal pass: 9260659 unique relations remain on slice 1 Info:Filtering - Duplicate Removal, removal pass: Of 20057179 newly added relations 18519283 were unique (ratio 0.923324) Info:Filtering - Duplicate Removal, removal pass: 18519283 unique relations remain in total Info:Filtering - Singleton removal: Starting Info:Filtering - Singleton removal: Reading 18519283 unique and 122177 free relations, total 18641460 Info:Filtering - Singleton removal: After purge, 1679486 relations with 1679326 primes remain with weight 32127890 and excess 160 Info:Filtering - Singleton removal: Have enough relations Info:HTTP server: Got notification to stop serving Workunits Info:Lattice Sieving: Cancelling remaining workunits Info:Filtering - Merging: Starting Warning:Command: Process with PID 23867 finished with return code -6 Error:Filtering - Merging: Program run on server failed with exit code -6 Error:Filtering - Merging: Command line was: /home/clavip01/math/cado-nfs-2.1.1/build/opn/filter/merge -mat ./tmp/A_8844_1553.c134.purge.purged.gz -out ./tmp/A_8844_1553.c134.merge.history.gz -maxlevel 20 -keep 160 -skip 32 -forbw 3 -ratio 1.1 > ./tmp/A_8844_1553.c134.merge.merge.stdout.1 2> ./tmp/A_8844_1553.c134.merge.merge.stderr.1 Error:Filtering - Merging: Stderr output follows (stored in file ./tmp/A_8844_1553.c134.merge.merge.stderr.1): b'# Warning: parameter nbmergemax is checked by this program but is undocumented.\nantebuffer set to /home/clavip01/math/cado-nfs-2.1.1/build/opn/utils/antebuffer\ncode BUG() : condition e == 1 failed in insert_rel_into_table at /home/clavip01/math/cado-nfs-2.1.1/filter/filter_matrix.c:100 -- Abort\n' Traceback (most recent call last): File "../../scripts/cadofactor/cadofactor.py", line 72, in <module> factors = factorjob.run() File "/home/clavip01/math/cado-nfs-2.1.1/scripts/cadofactor/cadotask.py", line 4720, in run last_status, last_task = self.run_next_task() File "/home/clavip01/math/cado-nfs-2.1.1/scripts/cadofactor/cadotask.py", line 4788, in run_next_task return [task.run(), task.title] File "/home/clavip01/math/cado-nfs-2.1.1/scripts/cadofactor/cadotask.py", line 3438, in run raise Exception("Program failed") Exception: Program failed |
- [Cado-nfs-discuss] Problem on the merge phase, Christophe Clavier, 12/11/2014
- Re: [Cado-nfs-discuss] Problem on the merge phase, Cyril Bouvier, 12/11/2014
