- To: Christophe Clavier <christophe.clavier@unilim.fr>
- Cc: cado-nfs-discuss@lists.gforge.inria.fr
- Subject: Re: [Cado-nfs-discuss] Problem on the merge phase
- Date: Thu, 11 Dec 2014 10:13:14 +0100
- List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss/>
- List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
Hello,
To understand where this bug comes from I will need the following log
files:
A_8844_1553.c134.merge.merge.std*
A_8844_1553.c134.purge.purge.std*
A_8844_1553.c134.duplicates2.dup2.*
A_8844_1553.c134.freerel.freerel.std*
I will also need the following files that may be bigger:
A_8844_1553.c134.purge.purged.gz
A_8844_1553.c134.freerel.renumber.gz
A_8844_1553.c134.polyselect2.poly
Best regards,
Cyril Bouvier.
[2014-12-11 08:49:18 +0100] Christophe Clavier:
> Hello,
> I have a problem on the merge phase of a factorization with cado 2.1.1.
> Hereunder is reported the end of the log.
> I have started again the factorization by importing the poly file and the
> relations but no more success.
> I have checked the relations with check_rels and they seem ok.
> Can anyone help me terminate this factorization?
> Thanks
> Christophe
> /Info:Filtering - Duplicate Removal, splitting pass: Starting//
> //Info:Filtering - Duplicate Removal, splitting pass: Splitting 1506 new
> files//
> //Info:Filtering - Duplicate Removal, splitting pass: Relations per slice:
> 0: 10027687, 1: 10029492//
> //Info:Filtering - Duplicate Removal, removal pass: Starting//
> //Info:Filtering - Duplicate Removal, removal pass: 9258624 unique relations
> remain on slice 0//
> //Info:Filtering - Duplicate Removal, removal pass: 9260659 unique relations
> remain on slice 1//
> //Info:Filtering - Duplicate Removal, removal pass: Of 20057179 newly added
> relations 18519283 were unique (ratio 0.923324)//
> //Info:Filtering - Duplicate Removal, removal pass: 18519283 unique
> relations remain in total//
> //Info:Filtering - Singleton removal: Starting//
> //Info:Filtering - Singleton removal: Reading 18519283 unique and 122177
> free relations, total 18641460//
> //Info:Filtering - Singleton removal: After purge, 1679486 relations with
> 1679326 primes remain with weight 32127890 and excess 160//
> //Info:Filtering - Singleton removal: Have enough relations//
> //Info:HTTP server: Got notification to stop serving Workunits//
> //Info:Lattice Sieving: Cancelling remaining workunits//
> //Info:Filtering - Merging: Starting//
> //Warning:Command: Process with PID 23867 finished with return code -6//
> //Error:Filtering - Merging: Program run on server failed with exit code
> -6//
> //Error:Filtering - Merging: Command line was:
> /home/clavip01/math/cado-nfs-2.1.1/build/opn/filter/merge -mat
> ./tmp/A_8844_1553.c134.purge.purged.gz -out
> ./tmp/A_8844_1553.c134.merge.history.gz -maxlevel 20 -keep 160 -skip 32
> -forbw 3 -ratio 1.1 > ./tmp/A_8844_1553.c134.merge.merge.stdout.1 2>
> ./tmp/A_8844_1553.c134.merge.merge.stderr.1//
> //Error:Filtering - Merging: Stderr output follows (stored in file
> ./tmp/A_8844_1553.c134.merge.merge.stderr.1)://
> //b'# Warning: parameter nbmergemax is checked by this program but is
> undocumented.\nantebuffer set to
> /home/clavip01/math/cado-nfs-2.1.1/build/opn/utils/antebuffer\ncode BUG() :
> condition e == 1 failed in insert_rel_into_table at
> /home/clavip01/math/cado-nfs-2.1.1/filter/filter_matrix.c:100 -- Abort\n'//
> //Traceback (most recent call last)://
> // File "../../scripts/cadofactor/cadofactor.py", line 72, in <module>//
> // factors = factorjob.run()//
> // File
> "/home/clavip01/math/cado-nfs-2.1.1/scripts/cadofactor/cadotask.py", line
> 4720, in run//
> // last_status, last_task = self.run_next_task()//
> // File
> 4788, in run_next_task//
> // return [task.run(), task.title]//
> // File
> 3438, in run//
> // raise Exception("Program failed")//
> //Exception: Program failed//
> _______________________________________________
> Cado-nfs-discuss mailing list
> Cado-nfs-discuss@lists.gforge.inria.fr
> http://lists.gforge.inria.fr/cgi-bin/mailman/listinfo/cado-nfs-discuss
- [Cado-nfs-discuss] Problem on the merge phase, Christophe Clavier, 12/11/2014
- Re: [Cado-nfs-discuss] Problem on the merge phase, Cyril Bouvier, 12/11/2014
