- To: "cado-nfs-discuss@lists.gforge.inria.fr" <cado-nfs-discuss@lists.gforge.inria.fr>
- Subject: [Cado-nfs-discuss] problem when using only size-optimized polynomial
- Date: Fri, 24 Apr 2015 21:20:16 +0800 (CST)
- List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss/>
- List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
Hi,
I try to use the polynomial that is only size-optimized to do factoring, the following error is displayed:
Info:Polynomial Selection (root optimized): Imported polynomial, skipping this phase
Info:Generate Factor Base: StartingI try to use the polynomial that is only size-optimized to do factoring, the following error is displayed:
Warning:Command: Process with PID 7095 finished with return code -6
Error:Generate Factor Base: Program run on server failed with exit code -6
Error:Generate Factor Base: Command line was: build/greatnet/sieve/makefb -poly /tmp/c150/c150.polyselect2.poly -alim 32000000 -maxbits 12 -out /tmp/c150/c150.factorbase.roots.gz -t 2 > /tmp/c150/c150.factorbase.makefb.stdout.1 2> /tmp/c150/c150.factorbase.makefb.stderr.1
Error:Generate Factor Base: Stderr output follows (stored in file /tmp/c150/c150.factorbase.makefb.stderr.1):
b'Error, N does not divide resultant of given polynomials\ncode BUG() : condition 0 failed in cado_poly_getm at /$home/cado-nfs/utils/cado_poly.c:201 -- Abort\n'
Traceback (most recent call last):
What should I do to fix it if I would like to use only size-optimized polynomial?
Thank you in advance.
Best regards,
Meng
- [Cado-nfs-discuss] problem when using only size-optimized polynomial, meng, 04/24/2015
- Re: [Cado-nfs-discuss] problem when using only size-optimized polynomial, paul zimmermann, 04/24/2015
- Re: [Cado-nfs-discuss] problem when using only size-optimized polynomial, meng, 04/25/2015
- Re: [Cado-nfs-discuss] problem when using only size-optimized polynomial, paul zimmermann, 04/25/2015
- Re: [Cado-nfs-discuss] problem when using only size-optimized polynomial, meng, 04/26/2015
