- To: meng <qsmeng@126.com>
- Cc: cado-nfs-discuss@lists.gforge.inria.fr
- Subject: Re: [Cado-nfs-discuss] problem when using only size-optimized polynomial
- Date: Fri, 24 Apr 2015 15:32:39 +0200
- List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss/>
- List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
Dear Meng,
> Date: Fri, 24 Apr 2015 21:20:16 +0800 (CST)
> From: meng <qsmeng@126.com>
> Hi,
> I try to use the polynomial that is only size-optimized to do factoring,
> the following error is displayed:
> Info:Polynomial Selection (root optimized): Imported polynomial, skipping
> this phase
> Info:Generate Factor Base: Starting
> Warning:Command: Process with PID 7095 finished with return code -6
> Error:Generate Factor Base: Program run on server failed with exit code -6
> Error:Generate Factor Base: Command line was: build/greatnet/sieve/makefb
> -poly /tmp/c150/c150.polyselect2.poly -alim 32000000 -maxbits 12 -out
> /tmp/c150/c150.factorbase.roots.gz -t 2 >
> /tmp/c150/c150.factorbase.makefb.stdout.1 2>
> /tmp/c150/c150.factorbase.makefb.stderr.1
> Error:Generate Factor Base: Stderr output follows (stored in file
> /tmp/c150/c150.factorbase.makefb.stderr.1):
> b'Error, N does not divide resultant of given polynomials\ncode BUG() :
> condition 0 failed in cado_poly_getm at
> /$home/cado-nfs/utils/cado_poly.c:201 -- Abort\n'
> Traceback (most recent call last):
> What should I do to fix it if I would like to use only size-optimized
> polynomial?
> Thank you in advance.
> Best regards,
> Meng
this is strange. Please can you send us your c50.poly file, your
cadofactor.py command-line, and the exact revision you used?
Paul
- [Cado-nfs-discuss] problem when using only size-optimized polynomial, meng, 04/24/2015
- Re: [Cado-nfs-discuss] problem when using only size-optimized polynomial, paul zimmermann, 04/24/2015
- Re: [Cado-nfs-discuss] problem when using only size-optimized polynomial, meng, 04/25/2015
- Re: [Cado-nfs-discuss] problem when using only size-optimized polynomial, paul zimmermann, 04/25/2015
- Re: [Cado-nfs-discuss] problem when using only size-optimized polynomial, meng, 04/26/2015
