cado-nfs - Re: [Cado-nfs-discuss] Problem compiling with cygwin on windows
  • To: Jason Xu <jasonx98@gmail.com>
  • Cc: cado-nfs-discuss@lists.gforge.inria.fr
  • Subject: Re: [Cado-nfs-discuss] Problem compiling with cygwin on windows
  • Date: Tue, 29 Dec 2015 08:17:18 +0100
  • List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss/>
  • List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
Jason,
> I have never used a mailing list before, so I hope this is the right place
> to report a problem/bug. I am using cygwin on Windows 8.1. Running make
> with cygwin terminal will run, but it repeats the same lines when trying to
> make. Curiously, in cado-nfs-2.2.0/build, there are two folders, XPS-8500
> (my computer name) and XPS-8500, which I have seen before as an issue with
> newlines when working with unix and windows.
> The following lines are repeated: [...]
this seems to be an issue with cygwin. In the end, did you succeed in
compiling
cado-nfs?
Paul
