cado-nfs - Re: [Cado-nfs-discuss] Problem compiling with cygwin on windows
  • To: paul zimmermann <Paul.Zimmermann@inria.fr>
  • Cc: cado-nfs-discuss@lists.gforge.inria.fr
  • Subject: Re: [Cado-nfs-discuss] Problem compiling with cygwin on windows
  • Date: Tue, 29 Dec 2015 04:27:46 -0500
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=jasonx98@gmail.com; spf=Pass smtp.mailfrom=jasonx98@gmail.com; spf=None smtp.helo=postmaster@mail-io0-f175.google.com
  • Ironport-phdr: 9a23:FJbNMB2Uke4oC3OTsmDT+DRfVm0co7zxezQtwd8ZsegRK/ad9pjvdHbS+e9qxAeQG96LtbQc06L/iOPJZy8p2d65qncMcZhBBVcuqP49uEgeOvODElDxN/XwbiY3T4xoXV5h+GynYwAOQJ6tL2PbrnD61zMOABK3bVMzfbSrXNaKx+2MlMmMuLTrKz1SgzS8Zb4gZD6Xli728vcsvI15N6wqwQHIqHYbM85fxGdvOE7B102kvpT41NdZ/i9Ro/Ms8dJbGeW/JvxgDO8QMDNzK2ko4IX5tBzGQBGK730aGjEumwdMRTrE6RT3RJL4tC3St+xn2SDcM9egHp4uXjH3za5wTxmguDpPYzww62bRmp0gpK1eqROl4Rd4xtiHM8muKPNic/aFLpshTm1bU5MUDnQZDw==
  • List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss/>
  • List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
Unfortunately, no. I don't think MinGW will fare any better. Running in the source folder gives the error "%1 is not a valid Win32 application", and running in build folder gives "ImportError: No module named 'cadotask'". By any chance, do you have precompiled windows x64 (or x86) binaries?
On Tue, Dec 29, 2015 at 2:17 AM, paul zimmermann <Paul.Zimmermann@inria.fr> wrote:
       Jason,
> I have never used a mailing list before, so I hope this is the right place
> to report a problem/bug. I am using cygwin on Windows 8.1. Running make
> with cygwin terminal will run, but it repeats the same lines when trying to
> make. Curiously, in cado-nfs-2.2.0/build, there are two folders, XPS-8500
> (my computer name) and XPS-8500, which I have seen before as an issue with
> newlines when working with unix and windows.
> The following lines are repeated: [...]
this seems to be an issue with cygwin. In the end, did you succeed in compiling
cado-nfs?
Paul
