- To: cado-nfs-discuss@lists.gforge.inria.fr
- Subject: [Cado-nfs-discuss] Problem running on multiple machines
- Date: Wed, 6 Jul 2016 13:26:01 +0300
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=vilgeforce@gmail.com; spf=Pass smtp.mailfrom=vilgeforce@gmail.com; spf=None smtp.helo=postmaster@mail-lf0-f67.google.com
- Ironport-phdr: 9a23:6fzOLRCUHUzKqc/T4ASfUyQJP3N1i/DPJgcQr6AfoPdwSP7+oMbcNUDSrc9gkEXOFd2CrakV06yM7eu5CSQp2tWoiDg6aptCVhsI2409vjcLJ4q7M3D9N+PgdCcgHc5PBxdP9nC/NlVJSo6lPwWB6kO74TNaIBjjLw09fr2zQd+KyZ7pnLnis7ToICxwzAKnZr1zKBjk5S7wjeIxxbVYF6Aq1xHSqWFJcekFjUlhJFaUggqurpzopM0roGxsvKcq/sJHFKP0ZOE0TKdTES89G2Q0/9Hw8xbNShGA6z0dVH8Xm1xGGVvr9hb/C70Yu8ITswNlkAyTJdEfpLAzc3z28aZvRxLmjz0MOhY29WjWjop7i6cN80HpnAB234OBONLdD/F5ZK6IJd4=
- List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss/>
- List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
Hello!
I'm testing cado-nfs on multiple mcahines. I started a master server, it works fine. Then I tried to connect slave to it and I got error message on both master and slave: "download/polyselect: /usr/lib/x86_64-linux-gnu/libstdc++.so.6: version `GLIBCXX_3.4.21' not found (required by download/polyselect)". I tried to understand what happened and realised: cado-nfs/build/cado-nfs/polyselect was copied to the slave machine and started there!- [Cado-nfs-discuss] Problem running on multiple machines, Владимир Мартьянов, 07/06/2016
- Re: [Cado-nfs-discuss] Problem running on multiple machines, Pierrick Gaudry, 07/06/2016
- Re: [Cado-nfs-discuss] Problem running on multiple machines, Владимир Мартьянов, 07/06/2016
