cado-nfs - Re: [Cado-nfs-discuss] Problem running on multiple machines
  • To: Владимир Мартьянов <vilgeforce@gmail.com>
  • Cc: cado-nfs-discuss@lists.gforge.inria.fr
  • Subject: Re: [Cado-nfs-discuss] Problem running on multiple machines
  • Date: Wed, 6 Jul 2016 12:46:58 +0200
  • List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss/>
  • List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
On Wed, Jul 06, 2016 at 01:26:01PM +0300, Владимир Мартьянов wrote:
> Hello!
> I'm testing cado-nfs on multiple mcahines. I started a master server, it
> works fine. Then I tried to connect slave to it and I got error message on
> both master and slave: "download/polyselect:
> /usr/lib/x86_64-linux-gnu/libstdc++.so.6: version `GLIBCXX_3.4.21' not
> found (required by download/polyselect)". I tried to understand what
> happened and realised: cado-nfs/build/cado-nfs/polyselect was copied to the
> slave machine and started there!
> For me it's strange: master and slave could have different architectures,
> library versions and so on. Is it a bug or feature? And how could I bypass
> this behavior?
It is a feature, but I tend to see it as a bug, indeed.
Anyway, when you start a client, you can use the --bindir option of the
cado-nfs-client.py script to tell where to find the binaries to use
instead of having them downloaded from the server.
Pierrick
