- To: meng <qsmeng@126.com>
- Cc: "18825954@qq.com" <18825954@qq.com>, cado-nfs-discuss@lists.gforge.inria.fr
- Subject: Re: [Cado-nfs-discuss] partal compile and sqlite3 error
- Date: Fri, 22 Jul 2016 15:29:54 +0200
- List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss/>
- List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
Hi.
On Fri, Jul 22, 2016 at 08:12:38PM +0800, meng wrote:
> When compiling cado-nfs-2.2.0 in the HPC, Wuhan university, whose
> configuration is as follows:
> gmp:6.1.0
> /home/yangm/cado-nfs-2.2.0/linalg/bwc/lingen_qcode_do.cpp:228: undefined
> reference to `mpn_xor_n'
This sounds very unlikely. Most probably you mixed up configurations
somehow. mpn_xor_n definitely should be exported by gmp-6.1.0 (this
function exists since gmp-5.0.0).
Please wipe out the build/* directory, and run "make" again. Or at least
check your gmp installation.
E.
- [Cado-nfs-discuss] partal compile and sqlite3 error, meng, 07/16/2016
- Re: [Cado-nfs-discuss] partal compile and sqlite3 error, paul zimmermann, 07/19/2016
- Re: [Cado-nfs-discuss] partal compile and sqlite3 error, meng, 07/22/2016
- Re: [Cado-nfs-discuss] partal compile and sqlite3 error, Emmanuel Thomé, 07/22/2016
- Re: [Cado-nfs-discuss] partal compile and sqlite3 error, meng, 07/25/2016
- Re: [Cado-nfs-discuss] partal compile and sqlite3 error, paul zimmermann, 07/25/2016
- Re: [Cado-nfs-discuss] partal compile and sqlite3 error, meng, 07/27/2016
