- To: "paul zimmermann" <Paul.Zimmermann@inria.fr>
- Cc: 18825954@qq.com, cado-nfs-discuss@lists.gforge.inria.fr
- Subject: Re: [Cado-nfs-discuss] partal compile and sqlite3 error
- Date: Thu, 28 Jul 2016 05:54:04 +0800 (CST)
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=qsmeng@126.com; spf=Pass smtp.mailfrom=qsmeng@126.com; spf=None smtp.helo=postmaster@m15-45.126.com
- Ironport-phdr: 9a23:WHneHxWQSmWDlnla3cUfeHHqNzPV8LGtZVwlr6E/grcLSJyIuqrYZhKBt8tkgFKBZ4jH8fUM07OQ6PG4HzJeqs7d+Fk5M7V0HycfjssXmwFySOWkMmbcaMDQUiohAc5ZX0Vk9XzoeWJcGcL5ekGA6ibqtW1aJBzzOEJPK/jvHcaK1oLshrj0pcOYO1kArQH+SIs6FA+xowTVu5teqqpZAYF19CH0pGBVcf9d32JiKAHbtR/94sCt4MwrqHwI6LoJvvRNWqTifqk+UacQTHF/azh0t4XXskyJVQKS4jMOU2ATnwBNCg7DplmuZp7stm3It+941TOfNMvwZbEyQzWrqalxHkzGkiACYjs09m6fwphpl6dWph2J/kYhhYXTZdfGZ7JFYqrBcIZCFiJ6VcFLWnkEW9vkYg==
- List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss/>
- List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
Dear Paul,
At 2016-07-25 21:38:53, "paul zimmermann" <Paul.Zimmermann@inria.fr> wrote: > Dear Meng, > >> >> When compiling cado-nfs-2.2.0 in the HPC, Wuhan university, whose configuration is as follows: >> >[...] >> >> gmp:6.1.0 >> >[...] >> >> /home/yangm/cado-nfs-2.2.0/linalg/bwc/lingen_qcode_do.cpp:228: undefined reference to `mpn_xor_n' >> export >> LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/home/software/lib64:/home/software/lib:/home/xxx/gmp-6.1.0/lib > >most probably there is an old GMP version somewhere in $LD_LIBRARY_PATH, >/home/software/lib64 or /home/software/lib. Please try with /home/xxx/gmp-6.1.0/lib >first: > >export LD_LIBRARY_PATH=/home/xxx/gmp-6.1.0/lib:$LD_LIBRARY_PATH:/home/software/lib64:/home/software/lib >
>Paul
Thank you for the advice. Besides your suggest, professor Hong from HPC added the following item to the .bash_profile last night and now cado-nfs-2.2.0 can be compiled completely.
export CXXFLAGS="-I/home/yangm/gmp-6.1.0/include -L/home/yangm/gmp-6.1.0/lib -O2"
Thank you again.
Best regards,
Meng
- [Cado-nfs-discuss] partal compile and sqlite3 error, meng, 07/16/2016
- Re: [Cado-nfs-discuss] partal compile and sqlite3 error, paul zimmermann, 07/19/2016
- Re: [Cado-nfs-discuss] partal compile and sqlite3 error, meng, 07/22/2016
- Re: [Cado-nfs-discuss] partal compile and sqlite3 error, Emmanuel Thomé, 07/22/2016
- Re: [Cado-nfs-discuss] partal compile and sqlite3 error, meng, 07/25/2016
- Re: [Cado-nfs-discuss] partal compile and sqlite3 error, paul zimmermann, 07/25/2016
- Re: [Cado-nfs-discuss] partal compile and sqlite3 error, meng, 07/27/2016
