cado-nfs - [Cado-nfs-discuss] Alterations to default param files for NFS
  • To: cado-nfs-discuss@lists.gforge.inria.fr
  • Subject: [Cado-nfs-discuss] Alterations to default param files for NFS
  • Date: Tue, 16 Jan 2018 22:50:37 -0800
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=vbcurtis@gmail.com; spf=Pass smtp.mailfrom=vbcurtis@gmail.com; spf=None smtp.helo=postmaster@mail-it0-f51.google.com
  • Ironport-phdr: 9a23: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
  • List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss/>
  • List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
I have done a large set of test factorizations from 100 to 125 digits, and wish to make my own param files every 3 digits rather than every 5.  Does CADO expect a params.c105 specifically, or can I change to params.c103, params.c106, etc?  That is, will CADO locate the param file of nearest size, or is every-5-digits how it's meant to stay?
Also, I have tested a set of parameter refinements that seem to improve substantially (Say, 15-25% less time to complete GNFS) upon the default param files included in 2.3.0; some weird choices are made by default, such as using I=13 in c95 but I=11 in c100. Should I send these possible improvements to the c105 through c120 default files to someone in particular?
