- To: Mike Curtis <vbcurtis@gmail.com>
- Cc: cado-nfs-discuss@lists.gforge.inria.fr
- Subject: Re: [Cado-nfs-discuss] Alterations to default param files for NFS
- Date: Wed, 17 Jan 2018 08:02:36 +0100
- List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss/>
- List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
Mike,
> From: Mike Curtis <vbcurtis@gmail.com>
> Date: Tue, 16 Jan 2018 22:50:37 -0800
> I have done a large set of test factorizations from 100 to 125 digits, and
> wish to
> make my own param files every 3 digits rather than every 5. Does CADO
> expect a
> params.c105 specifically, or can I change to params.c103, params.c106, etc?
> That is,
> will CADO locate the param file of nearest size, or is every-5-digits how
> it's meant
> to stay?
if a parameter with the exact size exists, it will be taken. For example you
can copy
parameters/factor/params.c60 to parameters/factor/params.c63, change name to
c63, and
if you factor a 63-digit number, the new file will be chosen.
But you can also easily modify the scripts to round to the nearest multiple
of 3.
See file scripts/cadofactor/toplevel.py, around line 163.
> Also, I have tested a set of parameter refinements that seem to improve
> substantially (Say, 15-25% less time to complete GNFS) upon the default
> param files
> included in 2.3.0; some weird choices are made by default, such as using
> I=13 in c95
> but I=11 in c100. Should I send these possible improvements to the c105
> through c120
> default files to someone in particular?
you can send them to me (c105, c110, c115, c120).
Best regards,
Paul Zimmermann
- [Cado-nfs-discuss] Alterations to default param files for NFS, Mike Curtis, 01/17/2018
- Re: [Cado-nfs-discuss] Alterations to default param files for NFS, paul zimmermann, 01/17/2018
